LeeM
Has anyone replace a parking/hand brake cable on a 2015 Passat? The maintenance manual does not indicate what has to be removed from the vehicle to access the cable so it can be replaced.
You might be able to remove the caliper and work the lever arm with some penatrating fluid to free it up. but not promise's the issue won't pop back up XXX miles down the road.Turns out I have a bad caliper. Lever for the parking brake on the right rear caliper is extremely hard to move and when I manage to move it, it won't return to the starting position unless I force it.
