NMS Parking Brake Cable
LeeM
Hagerstown,MD
2015 Passat SE, 2002 Jetta Reflex Silver
Has anyone replace a parking/hand brake cable on a 2015 Passat? The maintenance manual does not indicate what has to be removed from the vehicle to access the cable so it can be replaced.
You need a SHOP manual.
But the NMS is pretty easy, there is a little trap door in the bottom of the storage cubby in the center console. It just pops out after you remove the liner. Then you can access the end of the cables do disengage them from the equalizer bar.
pedroYUL
MI, USA
Well, I didn't know either how to access, and clearly I undid too much, but:
pedroYUL
MI, USA
And for reference, that nut to adjust the length seems to be 3/16" hex... definitely not a 5 or 6mm, perhaps a metric I don't have.
VernK
Kelowna
2012 Passat 2.5L Gas
Same size as the 5BA bolt head. BA (British Association) is actually a metric std for small threads and still very much in use in the world because it has a 45° thread angle, which is apparently better for small screws.
Yours
Vern
