jw4free
2012 Passat TDI SE
Summary: Engine CEL, Ran Ross VCDS scan, discovered code P026A and P0111. Cleared. Did research. Ordered MAP sensor (G31). Engine CEL again. Ran Ross VCDS scan. Got same Codes. Cleared codes. Pulled sensor. Discovered greenish oil/water condensation froth. Cleaned sensor, and replaced. Engine CEL again. Cleaned upper intercooler area with rag (limited success). Replaced sensor. Success.
Note Sensor G31 and G42 are a combined Bosch MAP and IAT sensor.
Sunday,12,February,2017,14:15:03:12876
(Scan truncated)
12642 - Charge Air Cooler
P026A 00 [237] - Efficiency Below Threshold
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 9
Mileage: 151073 km
Date: 2017.01.30 (Tuesday evening)
Time: 17:06:40
Engine speed: 2142.50 /min
Normed load value: 59.6 %
Vehicle speed: 113 km/h
Coolant temperature: 84 °C
Intake air temperature: 44 °C
Ambient air pressure: 980 mbar
Air mass at air mass meter 1: 118.2 kg/h
Temp sensor for low-pressure EGR after cooler: raw value: 103.3 °C
Outside air temperature: 16.5 °C
Intake air temperature before throttle valve: calculated: 25.3 K
Calculated temperature of compressor wall: 76.7 °C
5552 - Intake Air Temp. Sensor (G42)
P0111 00 [232] - Implausible Signal
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 151398 km
Date: 2017.02.02 (Thursday Morning)
Time: 06:43:17
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 3 °C
Intake air temperature: 37 °C
Ambient air pressure: 1000 mbar
Temp sensor for low-pressure EGR after cooler: raw value: -0.9 °C
Action:
Ran Ross VCDS scan
Ordered new MAP sensor after google, TDIClub forum searches
Saturday,18,February,2017,11:21:46:12876
(Scan truncated)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 152434 km
Date: 2017.02.13 (Monday mid day)
Time: 11:29:13
Engine speed: 1586.50 /min
Vehicle speed: 85 km/h
Coolant temperature: 86 °C
Intake air temperature: 49 °C
Ambient air pressure: 990 mbar
Air mass at air mass meter 1: 117.0 kg/h
Temp sensor for low-pressure EGR after cooler: raw value: 78.8 °C
Outside air temperature: 7.0 °C
Intake air temperature before throttle valve: calculated: 25.5 K
Calculated temperature of compressor wall: 66.7 °C
P0111 00 [237] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 152407 km
Date: 2017.02.13 (Monday Morning)
Time: 06:45:46
Coolant temperature: 1 °C
Intake air temperature: 45 °C
Temp sensor for low-pressure EGR after cooler: raw value: 1.2 °C
Action:
Wiped off sensor, sprayed down with Sea Foam and compressed air. Lubricated o-ring with dielectric grease, and re installed.
(Scan truncated)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Mileage: 151073 km
Time: 17:06:40
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 151398 km
Time: 06:43:17
Action:
Ran Ross VCDS scan
(Scan truncated)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 152434 km
Time: 11:29:13
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 152407 km
Time: 06:45:46
Action:
