200hp yes, 210-230 maybe, that said, I have a 50 shot, don't let anyone tell you nitrous is a waste of time or money, it works, I use it when I need it, people's jaws drop when they see a TDI blast by them with anger and fury, lol, it safe if not over done, 50 shot here, try it, you will like it, I PROMISE...Your TDI will never, EVER be fast. The sooner you realize this the better, lol.
Nitrous as this point is a complete waste of time. Upgrade your turbo and tune and enjoy 210-230whp.
200hp yes, 210-230 maybe, that said, I have a 50 shot, don't let anyone tell you nitrous is a waste of time or money, it works, I use it when I need it, people's jaws drop when they see a TDI blast by them with anger and fury, lol, it safe if not over done, 50 shot here, try it, you will like it, I PROMISE...that said never dynod my car with it but in the 250hp for a tdi is fast...and reduced EGT when spraying...
I have not seen it in this car yet, but still messing with it, in other Diesel trucks I have had it help buy only when on after off the gas temp will go back up, I need to get to the strip and do some runs, have a scangauge2 now to get more info on hand...Hi by how much is it lowering egt's.
Basically, more full, higher EGT's, if you just spray without adding fuel, yes it can lower EGT's...
Very true, I have a tuner that is going to map a few possibilities to see where we can take it...need to work with jet sizes to get a nice spray, I really don't use it that much, I had a system left over so decided to play with it...True! but just spraying with out having the extra fuel needed to support it to be able to add more power will definitely lower egt's but it will also lower the efficiency of the engine and will rob power.
A couple of guys who used to use it had it mapped into a different tune that they could switch in and out of when needed , which work out pretty well.
You're limited by fuel, all the nitrous in the world isn't going to help you blow by anyone.200hp yes, 210-230 maybe, that said, I have a 50 shot, don't let anyone tell you nitrous is a waste of time or money, it works, I use it when I need it, people's jaws drop when they see a TDI blast by them with anger and fury, lol, it safe if not over done, 50 shot here, try it, you will like it, I PROMISE...that said never dynod my car with it but in the 250hp for a tdi is fast...and reduced EGT when spraying...
Plenty of fuel in the CR engine to burn, and with mapping I have done all sorts of different thing to this ECU...You're limited by fuel, all the nitrous in the world isn't going to help you blow by anyone.
+1You're limited by fuel, all the nitrous in the world isn't going to help you blow by anyone.
Nitrous on a stock Cummins/Powerstroke/Duramax is useless. Why would you waste that $300 on a nitrous setup when you could get something like a PPE economy tuner for the same price and make how much more power?only way you make power with nitrous on a diesel is if you have unburnt fuel.
even on stock diesel trucks you can pick up 10 hp+ with nitrous...fyi
Sweet Avatar, I like the little SPRAY GUY NX...You don't need more fuel because you aren't spraying much to start with
Increase N2O nozzle + solenoid orifice diameters and/or upsize your turbo and you will see your HPFP needs some upgrading to a CP3 or CP4.2..
A little bit is often only enough for a short while![]()
thanks. that Avatar was originally Jeff's (rocketchip). he changed his some years back so i took it since i run NX stuff..Sweet Avatar, I like the little SPRAY GUY NX...![]()
I say a 50 shot, but like you said earlier, really don't know how much it is with the CR, lol...thanks. that Avatar was originally Jeff's (rocketchip). he changed his some years back so i took it since i run NX stuff..
been spraying N2O since almost 10 yrs. now
there is a reason the fastest TDIs use it. StingRayRT (ProfitTuning), the Finnish guys (yucca, hatemi), Gulu (DynoSoft), RyanP....all know how well it works![]()
Sounds like you should be driving a hOnduh and not a VW.Most of you on here have no idea, I have a 50 shot it works on our cars, we are not limited by fuel we are limited by a little turbo, I will race anyone with a CR engine with my mods and I guarantee my 50 shot will put me ahead, I'm using it, I know...
yes more ways to pick up MORE power then adding a nitrous system on a stock truck...Nitrous on a stock Cummins/Powerstroke/Duramax is useless. Why would you waste that $300 on a nitrous setup when you could get something like a PPE economy tuner for the same price and make how much more power?
As for the CRs there's a reason why guys are looking at upgraded pumps... Not enough fuel.
