NHTSA Update on CR HPFP failure investigation
dweisel
Wheeling, West Virginia
dweisel isn't diesel anymore!
This thread is for the News on safety related issues. This failure puts a person in traffic with either limp mode or total loss of power.
I wish you would go to the HPFP investigation thread and discuss the location of the filter with us there. Oilhammer thread.
In my opinion the HPFP has two pressure areas:
1..The main inner area where the cam, roller and slide are located. This area has 65psi (?) of pressure.
2..The High Pressure part of the pump where the 25,000psi is generated.
The wear materials are generated in the 65psi part of the pump. If you add a filter at 65psi you capture the wear materials before the High Pressure part of the pump and also filter the return fuel going to the tank. In other words: if you keep the wear materials out of the High Pressure part of the pump, it will not put trash into the common rail or injectors, and if the wear materials are captured at 65psi the return fuel will be clean.
I agree that it might seem necessary to filter at 25,000 psi, but it is not.
I do not want to flood this thread with all this. Please read the suggested thread or ask and I will restate any questions you have there (As much as possible by a shadetree jerk from Mississippi)
eddif
eddif, your ideas of filtering are great. BUT getting owners to implement your ideas is going to be a hard sell. You're just not going to get any CR owner to alter their fuel system at this point in time. Its going to take a few more years and failures out of warranty before someone takes the risk to put your ideas to work. I can see someone that has an out of warranty car that has traces of aluminum in their fuel filter willing to take the risk of installing additional filtering. BUT right now there isn't a necessity for that risk. The risk is just too high as long as VW is covering the cost of hpfp failures. Once VW no longer covers the cost of a hpfp failure..................everything changes.
oxford_guy
Ohio
Golf '11
What about when the fuel system fails right after the warranty expires because of cumulative damage?
P0234
NoVA
11 JSW
While I was at Lindsay VW, the sales guy was telling me about one of their own filling up a TDI with gas before they transfered it to another dealership. Of course "no damage was caused"......right.....
ZiggyTheHamster
Richmond, CA
2009 VW Jetta TDI
If I were at a dealer, and they admitted to misfueling a vehicle, and they carry more than one of those vehicles, that would be the last time I ever set foot at that dealer.
I don't know how many times the car says "Ultra-Low Sulfur Diesel Fuel Only", but it's at least 3 times that I can think of. And the cap says "Diesel" twice.
DEZLBOY
Arlington VA
2000 Golf GLS, Candy White
So the question is did Lindsay tell the receiving dealership and how likely is it that the car buyer was informed? I say 75% on the first, but "I gar-on-tee!" the buyer was left in the dark.
Ethical? And is it ethical for VW to sell the current TDI without telling the buyer of the fuel pump issue?
LRTDI
Red Sox Nation
RIP 16 GSW... Just the LR diesel now
Definitely not Ethical when Ethanol is added.....
Conan
Denver
2003 GLS TDI
That's an interesting point that I hadn't seen mentioned on here. If RUG is a pump-killer, then (I would guess) E85 would be even worse. I wonder if anyone (Bosch) has ever spun up a HPFP on a test bench, running gasoline through it until it grenades. It would be interesting to disassemble the pump at different gas-run intervals, and see how the thing starts to come apart. :confused:
oxford_guy
Ohio
Golf '11
E85 makes me laugh for a variety of reasons, but one of them is that it really should be called E70. Pumps say "contains a minimum of 70% ethanol".
Derrel H Green
Murrieta, California
An '05 MBZ E-320 CDI (W-211) replaced the '10 TDI JSW
Surprisingly they cover it under warranty at 84K miles . .
Perhaps 'they' are starting to see the handwriting on the wall and are finally
realizing that they had better start taking care of this problem or what
little good representation they have left will be totally lost! :p
Whatever, if they will do it for one person, won't they have to do it also for others
that might experince the same problem at higher mileages when 'out-of-warranty'? :confused:
:D
D
dweisel
:D
D
My understanding is that,right now VW is covering ALL hpfp failures until they determine the cause. So,even cars out of warranty will be covered at this point in time. BUT,thats all subject to change.
tico27464
Mid-Atlantic Traffic Jam, USA
2011 Golf TDI (DSG)
I wonder what the threshold mileage would be for them? Surely an '09 w/ 150K mi on the clock wouldn't be covered...would it? I'd love to hear I'm wrong about this. But this is why I'd rather mine go tomorrow or not at all.
~T
Elfnmagik
Sherman's Ashtray
Currently De-Dub'd
I've got 52K on the clock and getting nervous. I'm considering scheduling an appointment with the dealer to discuss/document the rusted rods on my lift pump, the sediment in the fuel, filter canister, and filter.
STRANGETDI
East Hampton, CT
2013 Audi A3 S-Line Premium Plus Quattro - APR Stage II
I am currently working with a few dealers right now as I am ready to get a 2012 TDI. Consumer Reports states that everything is good to excellent except the fuel delivery category. I beleive the latest data is for a 2010 or 2011. How is this problem being treated. I know there have been a few revisions of pumps since the issue started.
Are the pump failures related to diesel blends (biodiesel and veggie oil, and others) and such. I would use straight diesel and power service at fill ups, just like I have been for all these years with my 1999.5.
Just trying to get as much info as I can before I purchase my new VW.
oxford_guy
Ohio
Golf '11
There has been speculation about this but I haven't yet seen any hard evidence.
Is there anything in writing? Maybe, if VW is indeed covering out-of-warranty failed HPFPs, the reason is the current class-action lawsuit. I find it hard to believe that the cause hasn't been determined (the cause other than mis-fueling).
Lightflyer1
Round Rock, Texas
2015 Beetle tdi dsg
They fail with straight diesel. Bio (>5%) and veggi are not allowed in the newer models. The issue of HPFP failures seems to be tapering off as newer models have come out since 2009 or VW is covering them and not being reported by users as they are covered. Some use additves but IIRC some of those have failed as well (I may be wrong though about this). They are under investigation still by the NHTSA for this and no results have been released as yet that I know of. Good luck!
dweisel
I really wouldn't say failures are tappering off. Right now we have approximately 2/1 09's as compared to 2010 MY which have been out about half as long. So, 2010's would seem to have about the same failure rate as 2009's. The 2011's have not been out long enough to draw any conclussions yet.
2009 54 failures
2010 26 failures
2011 6 failures
MacBuckeye
North Carolina
2009 Jetta
"IF" VW is really taking ownership and have started paying for any/all HPFP's that fail (not for the gasoline filled), then would it not be cheaper for VW to have current owners with XXX1234 HPFP's come to the dealership for a newer version HPFP? A new HPFP is certainly cheaper than replacing the entire fuel system! :confused:
I'm sure we would rather have a new HPFP installed than have to go through the hassle of a possible wreck, getting stranded, towing charges, loaner vehicle, new fuel system, pain and suffering, hotel bill (while being stranded in some strange city), etc. etc. See where I'm going with this?
And to add to Dweisel's point, those failures (i believe) are only Member failures. Think about all those poor soles who purchased a TDI that crapped out on them! I'm sure there are a lot more failures out there... a lot more.
NickBeek
Upstate, SC
2013 Passat TDI 2006 Dodge Ram
Mac, you can bet some bean counter has run the numbers and decided it is less expensive to do it the way they are. Remember we are not sure they have the problem solved yet. Only VW knows and they aren't talking.
securityguy
Virginia
2009 Jetta TDI Sedan
I typically don't keep cars longer than 2 years but my wife and I love our Jetta. I really thought I'd keep it for several years to come and possibly pass it down to one of my twin boys while their in college but nixed that idea due to the possibility of them putting gas in it or having a HPFP grenade on them. I have decided to keep it up to 100K miles and then get rid of it. I bought the 5/100K mile VW warranty just in case anythying out of the ordinary happends but feel that 100K is plenty for me which I should hit in the next 2 years. Maybe by then, all of the HPFP issues and speculation will be behind us.
kjclow
Charlotte, NC
As nick said, we don't know for sure if the latest HPFP has solved the problems. Not enough time on them to know absolutely. If you figure a replacement charge of $1000 (est) per HPFP and VW has seen less than 1% failures to date, then you can see the economics of only working on the failures at $8000. Even at $100 per HPFP, VW is still ahead only fixing the failures. Based on that, I would not be surprised to see a "lifetime" warranty for the fuel system come out of this investigation.
Hopefully, Since VW is already involved with the NHTSA investigation, they will report all failures not just those of the effected tdiclub members.
Conan
Denver
2003 GLS TDI
...I would not be surprised to see a "lifetime" warranty for the fuel system come out of this investigation.
That would be the ideal solution for us, but I seriously doubt that VW will just volunteer for that.
