http://forums.tdiclub.com/showthread.php?t=284441
CR Engine HPFP Analysis (oilhammer thread)
This thread is for the News on safety related issues. This failure puts a person in traffic with either limp mode or total loss of power.
I wish you would go to the HPFP investigation thread and discuss the location of the filter with us there. Oilhammer thread.
In my opinion the HPFP has two pressure areas:
1..The main inner area where the cam, roller and slide are located. This area has 65psi (?) of pressure.
2..The High Pressure part of the pump where the 25,000psi is generated.
The wear materials are generated in the 65psi part of the pump. If you add a filter at 65psi you capture the wear materials before the High Pressure part of the pump and also filter the return fuel going to the tank. In other words: if you keep the wear materials out of the High Pressure part of the pump, it will not put trash into the common rail or injectors, and if the wear materials are captured at 65psi the return fuel will be clean.
I agree that it might seem necessary to filter at 25,000 psi, but it is not.
I do not want to flood this thread with all this. Please read the suggested thread or ask and I will restate any questions you have there (As much as possible by a shadetree jerk from Mississippi)
eddif
Then step up and install Eddif's proposed filters. Put your money were your mouth is.What about when the fuel system fails right after the warranty expires because of cumulative damage?
This isn't about me at all. It is a general point that responds to Dweisel's general point. I'm not sure why using me as a distraction is helpful.Then step up and install Eddif's proposed filters. Put your money were your mouth is.
If I were at a dealer, and they admitted to misfueling a vehicle, and they carry more than one of those vehicles, that would be the last time I ever set foot at that dealer.While I was at Lindsay VW, the sales guy was telling me about one of their own filling up a TDI with gas before they transfered it to another dealership. Of course "no damage was caused"......right.....
So the question is did Lindsay tell the receiving dealership and how likely is it that the car buyer was informed? I say 75% on the first, but "I gar-on-tee!" the buyer was left in the dark.While I was at Lindsay VW, the sales guy was telling me about one of their own filling up a TDI with gas before they transfered it to another dealership. Of course "no damage was caused"......right.....
Definitely not Ethical when Ethanol is added.....So the question is did Lindsay tell the receiving dealership and how likely is it that the car buyer was informed? I say 75% on the first, but "I gar-on-tee!" the buyer was left in the dark.
Ethical? And is it ethical for VW to sell the current TDI without telling the buyer of the fuel pump issue?
Surprisingly they cover it under warranty at 84K miles . .
My understanding is that,right now VW is covering ALL hpfp failures until they determine the cause. So,even cars out of warranty will be covered at this point in time. BUT,thats all subject to change.
Perhaps 'they' are starting to see the handwriting on the wall and are finally
realizing that they had better start taking care of this problem or what
little good representation they have left will be totally lost!
Whatever, if they will do it for one person, won't they have to do it also for others
that might experince the same problem at higher mileages when 'out-of-warranty'?
D
I wonder what the threshold mileage would be for them? Surely an '09 w/ 150K mi on the clock wouldn't be covered...would it? I'd love to hear I'm wrong about this. But this is why I'd rather mine go tomorrow or not at all.My understanding is that,right now VW is covering ALL hpfp failures until they determine the cause. So,even cars out of warranty will be covered at this point in time. BUT,thats all subject to change.
There has been speculation about this but I haven't yet seen any hard evidence.I know there have been a few revisions of pumps since the issue started.
Is there anything in writing? Maybe, if VW is indeed covering out-of-warranty failed HPFPs, the reason is the current class-action lawsuit. I find it hard to believe that the cause hasn't been determined (the cause other than mis-fueling).My understanding is that,right now VW is covering ALL hpfp failures until they determine the cause. So,even cars out of warranty will be covered at this point in time. BUT,thats all subject to change.
I really wouldn't say failures are tappering off. Right now we have approximately 2/1 09's as compared to 2010 MY which have been out about half as long. So, 2010's would seem to have about the same failure rate as 2009's. The 2011's have not been out long enough to draw any conclussions yet.They fail with straight diesel. Bio (>5%) and veggi are not allowed in the newer models. The issue of HPFP failures seems to be tapering off as newer models have come out since 2009 or VW is covering them and not being reported by users as they are covered. Some use additves but IIRC some of those have failed as well (I may be wrong though about this). They are under investigation still by the NHTSA for this and no results have been released as yet that I know of. Good luck!
Doesn't VW allow up to 5% bio?
As nick said, we don't know for sure if the latest HPFP has solved the problems. Not enough time on them to know absolutely. If you figure a replacement charge of $1000 (est) per HPFP and VW has seen less than 1% failures to date, then you can see the economics of only working on the failures at $8000. Even at $100 per HPFP, VW is still ahead only fixing the failures. Based on that, I would not be surprised to see a "lifetime" warranty for the fuel system come out of this investigation."IF" VW is really taking ownership and have started paying for any/all HPFP's that fail (not for the gasoline filled), then would it not be cheaper for VW to have current owners with XXX1234 HPFP's come to the dealership for a newer version HPFP? A new HPFP is certainly cheaper than replacing the entire fuel system!
And to add to Dweisel's point, those failures (i believe) are only Member failures. Think about all those poor soles who purchased a TDI that crapped out on them! I'm sure there are a lot more failures out there... a lot more.
That would be the ideal solution for us, but I seriously doubt that VW will just volunteer for that....I would not be surprised to see a "lifetime" warranty for the fuel system come out of this investigation.
