Smokin_Joe
ThxRead here:
http://forums.tdiclub.com/showthread.php?t=433465
The standard isn't the same as the fuel quality actually being sold.
I will look that over
ThxRead here:
Hi ATRThat's been a known issue for quite some time now. Happened to me once. Picked up a front grill block off from idparts last year and never had the problem again.
Very good info! thanks for sharing!, VW response to NHTSA pdf file.Now I received this message, along time ago, from my contact at the DOT.
When I followed his instructions and went there just now I find it lists 160 complaints and then it goes on to show that 120 or so were confirmed misfuelings???
This investigation, does it evolve, can we see the new complaint numbers.
Just curious...
The figures seem much smaller than I would have imagined.
[FONT=Calibri, sans-serif]Go to this website…
http://www-odi.nhtsa.dot.gov/owners/SearchSafetyIssues
Search for Engineering Analysis: EA11003
Regards,
Paul
[FONT=Arial, sans-serif]Paul Tiessen[/FONT]
[FONT=Arial, sans-serif]Motor Vehicle Defect Investigator[/FONT]
[FONT=Arial, sans-serif]Transport Canada, Motor Vehicle Safety Directorate[/FONT]
[FONT=Arial, sans-serif]Motor Vehicle Safety Investigations Laboratory[/FONT]
[FONT=Arial, sans-serif]80 Noel Street, Gatineau, QC J8Z 0A1 [/FONT]
[FONT=Arial, sans-serif]tel.819.994.3168[/FONT]
[FONT=Arial, sans-serif]paul.tiessen@tc.gc.ca[/FONT]
[FONT=Arial, sans-serif]Government of Canada[/FONT]
[/FONT]
Compare that to the number of cars sold in those years and you see how small that number actually is. It's like saying we need to fire every scientist in the world because 2 people died from Mad Cow disease...Thank you
I know statistically that isn't many based on total volume but looking at it realistically...659 lives were affected negatively in 2011 because they drove a TDI and 1784 were affected negatively in 2012 because they drove a TDI.
They aren't very fragile; and your Canadian fuel generally meets or exceeds a higher standard than US fuel does. Drive more, worry less...I am starting to think we may need to factor Stanadyne by the case for this fragile little creature.
That and lots of tlc.
.....I bought my Passat last fall knowing full well the contents of this thread. I still chose the TDI over the gas engine, and based on my time with a loaner a could of weeks ago I feel I made the right choice. As nice as the new 1.8T is, it can't hold a candle to the TDI driving experience.
When my HPFP was replaced I asked the service writer to recommend an additive, which he did. He then left the employ of the dealer.I am starting to think we may need to factor Stanadyne by the case for this fragile little creature.
It was the auto. I didn't feel the 1.8 was lacking, but it didn't have the diesel pull. Of course, the TDI has more torque. But i still far preferred the overall feel of the diesel. Fuel economy was outstanding, within 10-15% of my diesel. just wasn't as much fun to drive.question: what transmission did you have on the gasser?
I read many good comments on that new smaller 1.8TSI engine.
If it was a 6-auto "slushbox" it's harder to judge the difference.
I have yet to test drive one of the new 1.8s with a MANUAL to see how the improved torque feels on that engine vs. the TDI.
One of the reasons of being "on the fence" is the 'tune-ability' of the 1.8gasser - I would not dare to chip the diesel.
Thanks NateThe intercooler icing and HPFP are the only big issues I've heard of on the common rails. The Passats have had some turbo issues, but Jettas and Golfs have a different turbo.
There has been a HPFP failure on a car equipped with 2micron's kit, and the pump was the only thing that needed replaced. It was changed and they motored on.
Intercooler icing isn't an issue with my swap, and I installed the pureflow and (my version) of the containflow kit, so I'm not worried. If the HPFP does go, it'll be contained. I'll just try and get the CP3 kit and never worry about it again.
I think it actually recommends it.Nothing in the diesel fuel section of the manual that prohibits additives.
OkayCompare that to the number of cars sold in those years and you see how small that number actually is. It's like saying we need to fire every scientist in the world because 2 people died from Mad Cow disease...
There are just as many, if not more, failures in other car models that cause issues and have not been recalled or even covered by the manufacturer. VW is still repairing these failures even on vehicles past warranty; so they have stepped up...
I had a mkvi jetta with a 1.8t & automatic transmission For a work trip out in California. Even drove down the Pacific Coast highway in it. While it did lack the low down umph of a turbo diesel it did have more than enough go power for most situations.question: what transmission did you have on the gasser?
Volkswagen doesn't have a monopoly on that......
The level of technical know-how at the dealership continues to impress... by its absence.
That would have been scary.Joe, I wonder if your fuel in BC generally comes from the same refineries we get ours from here in western WA. If that's the case, you likely have fuel that is overall reliable. While there certainly has been some HPFP failures here, the total count is quite low.
My daughter accidentally mis-fueled their '09 Jetta, and even drove it for about 10 miles before it would no longer start. I had it towed to the dealer, who drained and flushed the tank, and it's been going fine for almost three years since. The mechanic pulled the head off the HPFP and found no metal, so their opinion was no damage occurred. Since it's been so long, it appears that was an accurate diagnosis.
It does seem that the areas that have had a BioDiesel requirement in their fuel for quite a while (like WA has) haven't had the failures as often as others. I have nothing to back this up, simply my observation over the years, along with our one personal experience.
Completely disagree. The number is probably a lot higher, but we'll never know the exact number plus the fact when it fails, it takes everything with it, ***?. The failure is unnacceptable, and it leaves a when will it happen to me feeling which is bs for a new car. Yes, cars have issues but this one WILL leave you stranded and its not a question of if, but when. If I owned one, taking a trip with kids would be a nerve racking experience. VW dropped the ball on this one big time.Compare that to the number of cars sold in those years and you see how small that number actually is. It's like saying we need to fire every scientist in the world because 2 people died from Mad Cow disease...
I have to disagree with this. I don't believe every single car will experience a HPFP failure, and that is what you are stating. Even if the total failures is double the reported number, it's still a tiny fraction of the total cars built. Yes, it's terrible to the person that it happens to, but don't claim it will happen to everyone....Yes, cars have issues but this one WILL leave you stranded and its not a question of if, but when..
DittoJoe,
With the refineries in Bellingham, it's possible they use gas lines rather than tankers if the ship cross border. I personally have no idea either.![]()
Just checked and this is true. The gasoline section talks about additives and say they are used to improve quality. It says to only use Volkswagen approved additives.Nothing in the diesel fuel section of the manual that prohibits additives.
Everyone can disagree.I have to disagree with this. I don't believe every single car will experience a HPFP failure, and that is what you are stating. Even if the total failures is double the reported number, it's still a tiny fraction of the total cars built. Yes, it's terrible to the person that it happens to, but don't claim it will happen to everyone.![]()
That's a pretty broad sweeping statement. There are CR TDI'S with upwards of 200k without pump failures. There's some at 400k! Of course it is true if you keep a car for it's life something will fail. From the amount of cars sold the ratio of HPFP to cars running well into 100k plus miles with no failure is pretty low.Yes, cars have issues but this one WILL leave you stranded and its not a question of if, but when.
OK, I will try to make this polite, please don't take it as something other than that, as it is hard to say this without sounding like I am attacking you (I am not...) BUTOkay
Don't want to BASH you or make you feel bad.
You aren't wrong!
From the prospective of business or government which is tied up in so much legal speak and excuses.
You are right!
They are trying to help the majority, of people benefit.
But!
Speaking as a person, a Canadian and a friend of the Americans who aren't afraid to speak their mind and scream about their rights....(just don't do it electronically... lol), one who is trying to survive and not make other peoples lives suffer so that we can enjoy life.
I am fragile and easily destroyed by the whim of big business and government.
The photos of the CP4, the internals, they really do look fragile and when you combine it with the lift pump in the tank which has a tendency to rust
http://forums.tdiclub.com/showthread.php?t=410742
and combine that with the underhood return mumbo jumbo that VW has done with the filtration system, eliminating the drain on the water separator???
(Yes Virginia the 2011 fuel filter is designed to separate water)
All this has created a fragile combo!
Thx Everyone
(all of the above are my opinions and experiences)
Your opinion is noted; and I completely disagree with just about everything you said.Completely disagree. The number is probably a lot higher, but we'll never know the exact number plus the fact when it fails, it takes everything with it, ***?. The failure is unnacceptable, and it leaves a when will it happen to me feeling which is bs for a new car. Yes, cars have issues but this one WILL leave you stranded and its not a question of if, but when. If I owned one, taking a trip with kids would be a nerve racking experience. VW dropped the ball on this one big time.
Actually, that is exactly what he said: He said every one of them will fail; which is complete crap. That's what "this one WILL leave you stranded and its not a question of if, but when"means; literally...Everyone can disagree.
"Yes, cars have issues but this one WILL leave you stranded and its not a question of if, but when.
He isn't saying each and every car, he is saying it is like having a little cloud of doom over your head that could strike at any minute.
ha! Yes... welcome to the club!.......It's best to stay away from this forum unless you have a problem that you need more information on. But, I am addicted to this forum and I can't stop!
No offence taken.........
Once again; drive more, worry less. If you are spending so much time trying to find problems with your car that you don't enjoy your car, then you are doing it wrong.![]()
I agreeI can completely understand the feeling. It's just he made it as a statement of fact. Perhaps I'm just reading it too literally, but again, that's just my feeling.
I can understand your feelings, based on the treatment received at your dealer. For me, I have a great relationship with my dealer, and perhaps changes my perception on the issue. I don't drive my car feeling it's going to fail on me. In fact, if I had to head cross country tomorrow, I wouldn't think twice.
There seems to be a significant difference between the way VWoA and VWCanada are handling the issue. I just shake my head when I read the way they have been treating so many of you, and that's a shame. You'd think the two would be more in sync.![]()
We almost sold our car after it crapped out the first time...Luckily VWoC stepped up when it let go a few months later, no fight just shock and awe as to everything that was gutted and replacedI had a 2002 TDI with an automatic transmission. Because of this forum I was convinced that my transmission was about fail. So I sold the car with 98000 miles on it. I recently met the person I sold it too and she now has over 250000 miles on it and the transmission is still fine. I almost traded in my 09 CR because of what I read on this forum about the fuel pump. I have 95000 miles on it now and it is the most reliable car I have ever owned. It's best to stay away from this forum unless you have a problem that you need more information on. But, I am addicted to this forum and I can't stop!
Hi my name is Joe and I too am addicted...lolha! Yes... welcome to the club!
I stop by this place several times a day![]()
