NHTSA Update on CR HPFP failure investigation
dweisel
Wheeling, West Virginia
dweisel isn't diesel anymore!
VW says its the fuel............................odd that the changes made to the 2012 tdi Passat makes the Passat's fuel pump able to cope with all this bad fuel that is casing all the earlier MY hpfp failures. And these numbers don't include the sudden rash of failures we have seen here recently. I'll bet VW is buried with failures right now.
Also interesting is that we had two 09's fail on fuel that two ALH Beetles are still running strong on. So, fuel or design?
sickmtbnutcase
SE WI
2009 Jetta TDI DSG
Is it based on the VIN? All I see under the Carline heading is "Jetta"
I am using Excel 2003, so something in the conversion may have caused this.
Excel 2003 can only display so many rows. Try LibreOffice if you don't have Excel 2007 or newer available.
Plus 3 Golfer
ARIZONA
Und tschüss! 2009 Jetta 12/23/2012
Well, looks like the less than one percenters and the 0.1 percenters need to readjust their thinking.:D
When I have time (or maybe someone else can do it), we need to compute the failures by MYs and mileage at failure. There should be enough data now to perhaps see some failure trends.
I thing I'll make a trip to the Ford dealer and get a trade-in value on my 2009 for a C-max.:eek:
darrelld
North Texas
2014 Tesla Model S85, 2017 Chevy Bolt
You won't regret making that trip. ;)
Claudio
IL
09 Jetta SW
it is scary for us 09 (but i guess that 10 11 and 12 are no better even if they have a supposedly reviewed pump) owners to know that a single or a few tanks of below quality fuel could cause a damage that could cost $8K. I mean 99% of the time I fill up at the same 2 stations and I used those for 108K miles now, but if I was traveling around i would not feel safe. at all.
if NHTSA does not do anything and the news spread around, that could be the death of diesel...who would buy one knowing that on random fuel test a lot of them resulted contaminated with water or gasoline, or not in spec?
darrelld
North Texas
The sheer magnitude of failures explains why they are taking the Amy1000 approach to repairs and not offering any extended warranty.
John96895
RI
Jetta, 2002, Black
Long time lurker on this thread, that spreadsheet is amazing.....and in 3 or 4 years likely to be jaw-dropping.
waltzconmigo
chicagoland
none
looks to me like 2micron may have a very viable "retirement funder" going forward with the retrofit pump:rolleyes: but in all seriousness, nearly 15% of all the fuel tested was outside of spec according to vw, this is a surprisingly high number. of course, we have no way of confirming this but we do know that other makes and previous vw models do not have problems too this extent. other than 2micron's efforts, not having designed in a post hpfp filter with the updated pumps is a major omission on vw's part.:confused: this seems to be a high enough percentage that bosch/vw should have known before release.
good luck everyone,
ciao,
waltz
sickmtbnutcase
SE WI
2009 Jetta TDI DSG
I looked again at my failure listed in the spreadsheet. It says No for stall while driving. That's bull****.
Lightflyer1
Round Rock, Texas
2015 Beetle tdi dsg
61 failed with less than 500 miles on them. 77.4% failed with a lubricity of 450 or less. From the fuel testing document.
STEye
MD
08 STI / 12 Impreza
Has there been any 2013 Jettas that have failed in decent quantities? I am on the edge about trading in my 2012 Impreza for a 2013 Jetta TDI (I have a thread in the Jetta section). Seeing all these failures makes me nervous. The design for the 2013 is the same, so I would assume that the failure would continue to exist? Looks like the general consensus is to stay away from the Jetta TDI!
Claudio
IL
09 Jetta SW
thpreadsheet would be also good to check what % of people is reporting their failures here
Lightflyer1
Round Rock, Texas
2015 Beetle tdi dsg
Not necessarily stay away, but you hope you aren't in the 1% to 5% that have been hit.
kjclow
Charlotte, NC
from another table it seems vw had 5891 complaints about HPFP, that would make 2.45%
In post 4463, VW says they have 5891 complaints with 5208 unique vins. That would indicate 683 vehicles had multiple failures like amy1000.
darrelld
North Texas
I would take a mirror to the dealer and see if it has the Czech made pump. The 2012 Golf TDI we have in our household is using the German made pump.
kjclow
Charlotte, NC
4 samples were found to contain increased amounts of water more than 1.5 % / 1.8% /
2.5 % and one sample exceeding 10% of water, which was not detected in the fuel
station and random vehicle surveys. Viscosity and lubricity are within specification, but
water could cause rust and corrosion in the HPFP and damage the pump.
I must have missed something in basic science and chemistry but I have always been taught that aluminum doesn't rust. IIRC, the hpfp is aluminum and therefore should not rust or corrod with any amount of water. The water may have adverse effects with other parts of the fuel system.
