SRHeer
With check eng light on, I went to check and clear codes with Blue Driver OBDII diagnostic tool.
Its blue light didn't light up to indicate communication with ECM - I then hardwired my Dell with Vag-Com program from
its 9 pin serial port to OBDII test port but it did not run and says problem with interface or that it is not plugged in so -
does that mean I am missing power and or not getting a good ground to the OBDII test port? I don't think there
is a fuse or other connection between ECM and test port is there?
