GrapplingDMC
Ok I put this in the wrong section & was told this is where it goes so hopefully someone here is familiar with this issue:
I bought a 1997 Passat TDI wagon for $600. Test drove it & no issues but on the way home it went into limp mode. When I started the next day, issue was gone then came back on. I believe it has happened 3 times & all at freeway speeds. No check engine lights. The motor has 267k on it. Power on it when not acting up I am more than impressed with. I took my Edge 2 controller and plugged it into the TDI but it does not seem to read the boost and was no VW to select, just had to click "other". Not sure if there is an update that can do more, I will look. The car had some motor work a little over 30k ago: Crankshaft, rod bearing set, crackshaft gear, front & rear seal, main bearing set, lower timing cover, clutch disc, release bearing, oil pan gasket, boot, connecting rod bolt, seal/flange, timing cover. There was some screws, bolts & lube too. The other thing is 5th gear is out. Where do I start on troubleshooting? I will buy a code reader if it helps. If so what would be a good one with out breaking the bank?
