This sounded very odd to me, so I pulled out my HEX-USB+CAN cable and fired up Vag-Com Beta 711.1 to check on my 2006 Golf. I neglected to get logs, so I'll do that this evening.
Let's work in native units, which Vag-Com (and the ECU) work in. You verified 0.3 gallons/hour at warm idle. 1 US gallon = 3.785 liters (
source) & 1 liter = 0.264 US gallons (
source), so you say that at warm idle, you're burning (0.3 US gal * 1 liter/0.264 US gal) 1.136 liters per hour.
I fired up Vag-com when I went to lunch, and with all accessories off and the engine idling from a cold start, Vag-com was reporting fuel consumption of 0.6 liters/hour (53% less than your figure).
Once it was fully warmed up (after a half hour drive), Vag-com reported 0.4 liters/hour (65% less than your figure) at idle with all accessories off.
Unless you had every single accessory blazing while you took these measurements (plus a few extras) or mistook the Vag-com measurements for gallons/hour when they are actually liters/hour (which IMO is probably the crux of the issue), I don't see how this is possible unless your car has injector issues. Many other users have reported nearly the same figures (0.3 - 0.4 liters/hour at warm, accessories off idle) from Vag-com, which gets its information from the engine ECU.
