Why do I get better MPG driving country roads than. Highway
Your average speed is lower. High speeds decrease my mileage as well.
erlelilyn said:Why do I get better MPG driving country roads than. Highway
Yeah that's something I regularly mix up. Edited. Thanks.Jnitrofish, Great explanation... but I think you meant to say "at lower rpm" instead of "lower gear" a couple of times there?
Yup ... edited explanation is spot on folks.... a scanguage helps to verify what he just said. The proof is in several successive fillups.Yeah that's something I regularly mix up. Edited. Thanks.
I got a prime example of how true this is, many years ago on a trip to Panama City from Birmingham. A friend and I left out at about 3 am to stay out of the traffic and sun. We drove all night along a route that was 40% interstate, 60% US highways.Slow (constant/rural road driving) is optimal, since you can cruise for a long time in a high gear (low RPM) without much throttle at all due to the lower amount of wind resistance (aerodynamic drag) from trying to slice through the air at a lower speed. Result is great MPG.
Actually, shutting down the engine and restarting by using driveline power is hard on the engine components. i have done it myself but it is much more of a strain on engine bearings than using the starter to fire it up.In a manual trans car you pay more attention not less when cruising with then engine off which equals safer . If I see I'm going to need more acceleration I can have it running in about the same time it takes someone to get back on the throttle in a running car .
When you see you are going to have to stop or need extra acceleration just use your momentum in the highest gear possible to re crank the engine just as it is required saving battery power & starter life .
If this is done properly no more strain is put on the drive train than shifting gears up or down or accelerating & decelerating in gear . Just let the clutch out just enough to get the engine going no more then get into the required gear drive off .
In an automatic it does take more electricity which equals more fuel used less fuel saved to do this but there is a payoff if done with care . Plus the extra strain put on the starter .
How?Actually, shutting down the engine and restarting by using driveline power is hard on the engine components. i have done it myself but it is much more of a strain on engine bearings than using the starter to fire it up.
Its not made up its a fact and I'm relaying the info to help someone. Regular filters are made of filter materal (paper). KNN filters work on the principle of a thick liquid (oil) whick traps and holds the dust and dirt. A turbo charged engine created a lot of suction and pulls the oil out of the filter which is loaded with dust and dirt and it ends up in the engine and scratches the internal components ruining the engine. A normally asperated engine does not produce the suction that a turbo charged engine produces and as such a KNN filter is more sutable for that application.Say WHAT?
Make up something else.
Do not use a KandN filter on a TDI, but the fact that the TDI has a turbo has absolutely nothing to do with why you should not use one on a TDI.
Bill
OK to #'s 1Thanks ruking! I appreciate the honesty and help.
1. I will pay better attention to the break-in recommendation via the threads and the owners manual. I should have defined what I meant by conservative. I don't go 90 mph down the highway...everyone in Texas does, just the way people drive. My life isn't worth getting to work 3 minutes earlier, which is why I stick in the 60-73 mph range.
2. I am not really looking to B/E, it is more the principle of fuel economy. I have frequent long cummutes. My daily commute is 45 miles each way, and I often travel home which is 700 miles. I am hoping to be part of the 700 mile or even 800 mile club someday. Getting home on one tank of gas would be rather funny to me considering how things use to be
3. I am seeing MPG around 46 on full tank. Which is great. Better than EPA estimates of course which aren't even close. I am more than pleased. I am just hoping to get to 50 mpg * 14.5 Gallon Tank = 700 mile club. (No, I will not run it down to zero just to achieve this.)
Defacto, that puts me in that category also. But there are a fair amount and % of folks who are disappointed @ the fuel mileage they do get.I am BS'ing? Huh....interesting assumption. Making the newbie feel welcomed
Hello, I`m a newbie to this site, but not to diesels. Sometime back I purchased a used 98 jetta TDI. It ran well, but I was getting 42mpg. I was disappointed having just gotten rid of a P.O.S. 85 jetta TDI ( no such thing ) that was getting 50-56mpg, but was falling apart around the engine.
What's your guys take on the www.advancedautomotion.com Drop in 6 Speeds for the MKIV/MKV Save Thousands! thread? When I have to have the clutch changed thought of this upgrade.
Very true, that's cheaper. Thing is I don't prefer tall skinny tires. I like tight handling in corners, sporty looks, etc. That's just my preference.A cheaper and better working idea is the one I've been using for over 30 years . Just install taller 75 series tires and inflate to 38-40 psig on any car of any type and you will see a rise in mpgs , I have 3,000,000+ miles of clocked data on all types of cars gas & diesel to back up that statement . This raises the gearing , makes all the gears taller not just the highest gear . If you use this gearing improvement properly you will a rise in mpgs .
That's one of the (many) pleasant things about our TDIs. We still manage to get pretty good mileage while not compromising on handling and driveability. Part of what gets a Prius such great mileage is all the bits they shave off, like having narrow tires. I'd rather stick to the road more and lose a few MPGs.Very true, that's cheaper. Thing is I don't prefer tall skinny tires. I like tight handling in corners, sporty looks, etc. That's just my preference.
Arguably you are not loosing any MPG depending on your driving habits. Might even gain some by driving a TDI vs a Prius.I'd rather stick to the road more and lose a few MPGs.
Two main things that auger in your favor. Probably first and foremost is the VW (TDI) is really designed for the autobahn. Prius while it can probably handle the autobahnn, is NOT. Second, the Prius/TDI is a apples to oranges, strawman comparison. When you consider the power specifications a more even one is the Camry Hybrid/ VW TDI comparison. In most every measure in that comparison, the VW TDI Jetta wins over the Camry/Hybrid. Lower priced, better mpg, better adaptation to the American system of roads.That's one of the (many) pleasant things about our TDIs. We still manage to get pretty good mileage while not compromising on handling and driveability. Part of what gets a Prius such great mileage is all the bits they shave off, like having narrow tires. I'd rather stick to the road more and lose a few MPGs.
Even with all the pot holes we have on our roads?Two main things that auger in your favor. Probably first and foremost is the VW (TDI) is really designed for the autobahn. Lower priced, better mpg, better adaptation to the American system of roads.
