To all you neutral coasters:
I used to do that (kick car into neutral on long downhills), especially on the way home from my former job. One hill in particular, I could reach 80+MPH by the bottom of the hill and coast quite a long way before I slowed back to 55MPH and put the car back into gear. Other hills on the way home allowed 1+ miles of coasting as well.
Two things made me stop:
1. Didn't really see any MPG improvement over driving normally.
2. THP was sitting at the bottom of the big hill I mentioned above and I received a Fast Driver Award totalling $182 as a result.
On every time I've ever advocated coasting in "N" I've made sure I note that this should not be ,
never be done in situations where excessive speed is built up ! If you
only do this in situations like you describe you are likely not to see that much improvement , maybe one or two mpgs over a tank if you don't hammer the power in to keep speed going back up hill . If you hammer the power in to keep speed going up hill you will not see much if any gain , maybe a little lose of mpgs if you really push it going up hill or wait too long to get back on the power .
And on not gaining any mpgs if done properly , I call bullsh!t ! . On every car I've ever done this on I gained
at least a couple of mpgs , 3-5 minimum over a tank where this is done whenever possible .
When combined with the use of "N" in city driving on streets where no extra speed is needed & while coming up to a stop and while at a stop , looking far ahead giving the needed room between cars in front of you to avoiding complete stops as much as conditions will allow with no jack rabbit starts during the tank I've documented as much as a 7-10 mpg improvement . One hard start is all can take to do away with the gas/fuel savings .
In fact I just documented over a several tanks in a Corolla an improvement from ~28-30 to 37+ mpg city by using these techniques . I took a 05 Accord from 24-25 to almost 30 mpgs on city only loops .
These numbers are while driving around the Denver metro area in traffic and from filling to the brim of the filler neck each time which is the only way to be sure you get accurate fill data to calculate consumption .
NOTE , if the car is going to not be driven at least 10-15 miles right after the fill it should not be over filled like this !!!!! Filling up to top of the filler neck then parking can do damage to vapor recovery system in a gasoline car .
If these techniques are used properly you will achieve higher mpgs on city loops than on higher speed highway only loops . I have over 30 years of documentation to back this fact up ....
