riofrio
Hi folks,
I just bought a 2002 Jetta Wagon (details at http://forums.tdiclub.com/showthread.php?t=299022). I got it at a used car lot, and having had a B4 for several years, I inspected it to the best of my ability, scanned codes with VCDS (found none), and found the car to be in near excellent running condition, so I decided to take my chances.
Immediately after buying it I took it to TDI Guru Jeremy (Fase2000TDI), and during the timing belt change discovered that the head in place is not a VW OEM (likely one of those spanish units, but not certain). It seems very probable that this car had a TB break and was "fixed" by placing an aftermarket head, and the TB wasn't even done properly afterward (mark and pray, rollers and water pump re-used). Luckily it didn't have another TB failure as a result.
Pulled the valve cover and noticed a good 2mm of wear on at least one lobe, and some minor wear marks on some of the followers. I am assuming this is what happens when the moving parts in the head don't have the proper tolerance specs. Jeremy went ahead and finished the TB belt job and urged me to consider getting a properly rebuilt head by Frank06 as soon as possible (plus new camshaft and followers), with which I fully agree.
My only concern here is finding uglier stuff upon removing the head, whether piston damage or block damage. I don't know the history of the car and can't assume anything: could have been a broken TB, run out of oil, runaway engine, who knows. All I know for sure is that it runs great as it is, has very good power, idles and accelerates smoothly, and does not seem to consume oil or smoke more than normal. Can I take these as indications that most likely all is well and getting a proper head in place will set me straight? Other than doing a compression check, and inspecting the block for visual signs of damage, is there anything I can do before removing the head?
By the way, anyone in the northeast looking for TDI service, Jeremy is the man! Extremely thorough, knowledgeable and great guy to deal with. Worth every penny!
