towforce
Recently upgraded my KP39 to VNT-17 on my BEW, had posted this thread:
http://forums.tdiclub.com/showthread.php?t=499700
The upgrade went well and has solved my oil consumption issue. I really like the smoothness of the 17 but I'm now left with a new, minor issue that has yet to be resolved.... under steady load on a hill, mild throttle application, there is a very brief "hickup" or "stutter" (only a second or two), then back to normal. As much as I try, I can't force/duplicate the event.
No Codes are being logged. I have tested the throttle peddle output, seems normal with no issues. Cleaned various suspect connections (MAF and such).
We ran a interesting test where if we were on a hill holding at 2000 rpm or less and there would be no stutter, but if we held the same hill at 2200+rpm, we would get the occasional stutter.
I'm running a Malone Tune, Stage One that was setup for the KP39, I was told the tune would work with the 17 but I'm not sure if there is any differences that may be causing the issue.
I can't see it being related to a fuel issue, far too infrequent, if you punch it, the problem is gone (and like I said, can't force the event, its random and not very often). The stutter is so brief that I have yet to spot if the tach is jumping around so I doubt it is the cam sensor (?).
Anybody got any suggestions?
Martin
Martin
