Jesse_Garron
Howdy,
I've looked through quite a few posts, so hopefully this isn't too redundant.
Just got a '99 New Beetle, 65K miles, and is my first TDI. So, I have a few questions.
Timing Belt - this seems to be very popular is as it is so essential. Local VW (independent) guy did the pre-purchase inspection. Only thing he noticed that needed work was the TB procedure. His list of parts included most, if not all of the items on the .pdf for belt replacement including bearings, both belts, mounts, water pup, etc. I am not going to do this myself, so can you folks recommend a mechanic?
Bio-diesel. I'd like to start running Biodiesel, however... I have no idea if this car has ever had anything but dino diesel. Is my only concern sediment in the fuel filter? Any down side? If it's just the filter - should I wait till I've run a tankful of 100 thru to change filter? I'd rather get the timing belt procedure dome ASAP, but will I be paying more to have the fuel filter changed separately? Seems to be located away from everything else, so it doesn't seem so.
Also, where in the heck can I get biodiesel? I found Ward Oil co, but it seems they only sell 55 gallon drums. Any retail outlets suggested, or may I purchase some from someone here?
I'd be interested in attending any meets, so I'll be looking out for those.
Thanks to all.
J.G.
Thanks to all.
J.G.
