loganbmx4gt
After a new turbo replacement on my friends car, 2005.5 Jetta, it was in a limp mode(ish) state. It would barely do 20 mph and smoked horribly. I deleted all the codes from each controller and it gained life back. It's wanting to shift at really high rpm's (4000) now. I am copying the auto scan in this thread. The engine controller not being able to be reached bothers me and i wanted to pick the brains of those that know more. Thank you in advance.
Wednesday,30,March,2016,09:05:10:51436
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 15.7.4.1
Data version: 20160216
www.Ross-Tech.com
VIN: 3VWRT71K25M634631 License Plate: BRANDONS CAR
Mileage: 164030km-101923mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 72 7D
VIN: 3VWRT71K25M634631 Mileage: 164030km-101923miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 042 H HW: 02E 927 770 AD
Component: GSG DSG 041 0905
Revision: 04004010 Serial number: 00000501200283
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 1835D2B82B5B47FEA6-804C
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021122
Shop #: WSC 00066 000 00000
VCID: 3A712830759775EE70-806E
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AG
Component: ClimatronicPQ35 066 0505
Shop #: WSC 00000 000 00000
VCID: 6CDDDE684F431B5EB2-8038
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 C HW: 1K0 937 049 C*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000000054386
Coding: F4098E02400418000014000000140000002077035C
VCID: 2F670964BED5A046D7-807A
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00000
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 00000
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 39 AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D07T3ZL
Coding: 0013113
Shop #: WSC 25642 444 92495
Subsystem 1 - Part No: 1K0 959 339 B
Component: BF-Gewichtsens. 006 0003
Subsystem 2 - Serial number: 6332MSME09141251.
Subsystem 3 - Serial number: 6342MSME092F4570E
Subsystem 4 - Serial number: 6351HSME065C486BJ
Subsystem 5 - Serial number: 6361HSME06496F14D
Subsystem 6 - Serial number: 63727SME06360862Y
Subsystem 7 - Serial number: 63827SME06370338Y
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AB HW: 1K0 953 549 AB
Component: J0527 010 0045
Coding: 0010041
VCID: 72E1C0106D67CDAE78-8026
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 971 D
Component: KOMBIINSTRUMENT 3HL 2120
Coding: 0023203
VCID: 2C5D1E688FC3DB5EF2-8078
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 2700105204188A
Coding: 3F3F0B400F1002
VCID: 2953E77C8031CE7609-807C
1 Fault Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 254
Reset counter: 113
Mileage: 82043 km
Time Indication: 0
Date: 2000.00.00
Time: 14:02:15
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K5 919 965 HW: 1K5 919 965
Component: Kompass 002 0001
Revision: 00002000 Serial number: 0371356TNVMG03
VCID: 78F5F2380B1BA7FE46-802C
2 Faults Found:
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 153
Mileage: 97229 km
Time Indication: 0
Date: 2000.00.00
Time: 09:09:34
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 153
Mileage: 97229 km
Time Indication: 0
Date: 2000.00.00
Time: 09:09:34
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 2120
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1K0 959 701 L
Component: Tuer-SG 024 2475
Coding: 0001270
Shop #: WSC 25642 444 52570
VCID: 37773104468568868F-8062
3 Faults Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation
00100 - Drivers Interior Locking Button (E308)
008 - Implausible Signal - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.3 1502
VCID: 30650A18A3EBBFBECE-8064
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AT HW: 1K0 959 433 AT
Component: KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 13100F880106281B0906050FA0080F0490A540
Shop #: WSC 25642 444 68437
VCID: 020190D05DC7FD2E68-8056
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
2 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01110010
Fault Priority: 4
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
00930 - Locking Module for Central Locking; Rear Left (F222)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01110011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 111
Mileage: 120538 km
Time Indication: 0
Date: 2000.00.00
Time: 01:01:56
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Component: Tuer-SG 024 2339
Coding: 0001271
1 Fault Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
012 - Electrical Fault in Circuit
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 C HW: 1K0 035 180 C
Component: Radio DE2 011 0014
Revision: 00011000 Serial number: VWZ4Z7E2040491
Coding: 0040400
VCID: 2045FA58F30B0F3E5E-8074
2 Faults Found:
00856 - Radio Antenna
011 - Open Circuit - Intermittent
02218 - Satellite Radio (R146)
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2416
Coding: 0000144
VCID: 31630F1CA8E1B6B6C1-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 32610010ADE78DAEB8-8066
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D5B136CB4D9D256E5-8078
End-------------------------(Elapsed Time: 01:59)--------------------------
www.Ross-Tech.com
Address 01: Engine
Cannot be reached
Coding: 0000020
Coding: 0021122
Coding: 00065493
Shop #: WSC 00000
Coding: 00217125
Shop #: WSC 00000
Coding: 0013113
Coding: 0010041
Coding: 0023203
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Reset counter: 113
Mileage: 82043 km
Time Indication: 0
Date: 2000.00.00
Time: 14:02:15
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 153
Mileage: 97229 km
Time Indication: 0
Date: 2000.00.00
Time: 09:09:34
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 153
Mileage: 97229 km
Time Indication: 0
Date: 2000.00.00
Time: 09:09:34
Coding: 0001270
3 Faults Found:
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 111
Mileage: 120538 km
Time Indication: 0
Date: 2000.00.00
Time: 01:01:56
Coding: 0001271
1 Fault Found:
Coding: 0040400
2 Faults Found:
Coding: 0000144
Coding: 0000144
