54inches
Good Evening!
Just picked her up tonight, so I'll be doing some reading for sure!
Welcome! Nice looking car!
I suggest not using the site search and just open google to search for what you are looking for. Not being snarky, the local search is not real good. I find that google usually points back here most of the time when I search.I am searching away on the forum, but it looks pretty dead. Is there a better resource for these little monsters?
No snarkiness received! lolI suggest not using the site search and just open google to search for what you are looking for. Not being snarky, the local search is not real good. I find that google usually points back here most of the time when I search.
I bet there are more specific sites that deal with Audi, but may be limited with regard to TDI. I imagine it depends on what you are looking for. Suspension stuff seek an Audi A3 page, Motor stuff may be here??
What are you looking for?
{Welcome back DavidR8!}
Whatcha got?Hi everyone, just joined the forum. I’m here to learn, share, and hopefully contribute to the community. Looking forward to connecting with fellow TDI enthusiasts.
Programmable Search Enginecse.google.com![]()
Just a friendly piece of info, You can highlight a part of a post and you will see a box to quote the message in your next post. You can even stack the quotes or use in another thread. {just don't forget to remove ones you didn't use, if you change topics} You will see a button to 'add quotes' at the bottom of your post input box. This is very useful in busy threads so you can highlight the part of a post to which you refer.In general, just info.
Not mine, credit member walleyz
Welcome to the forum, but you can't be so new to the Internet that you don't know about google translate. You are putting the burden of figuring out whether others will want to do that and help you.buenas buenas me presento recien ingrese al foro debido a que altener poco tiempo con el auto nome habia dado ningun problema pero en cuestiones de mantenimiento saliero y aqui me tienen leyendo todo para encontrar la solucion a mis fallas saludos desde mexico
Welcome to the TDI Club....Hi I'm Billy and rehomed a 09 jsw with a dsg and 167xxx mi. I was poking around and noticed my timing belt cracking (its parked for the moment) is there a good recommendation on a timing belt kit and any special tools needed and possibly the the procedure to time the motor oh and I believe the engine code is CBEA thanks in advance !!
ThanksWelcome Ty, you've come to the right place.
cse.google.com
That car will have an ALH engine, which does not have a lift pump in the tank. The first steps I would try is to bleed the fuel lines which requires a vacuum pump to get fuel to the injector pump, followed by cracking open the lines at the injectors and cranking the engine to bleed the high pressure lines. There's plenty of writeups on here of how to do this that can be found with the search function.Hello! My daughter got herself a 03 Jetta TDI. She had the oil pan changed (preexisting issue), and now it won’t start. It cranks, but won’t fire, no smoke. We did crack the fuel line into the fuel filter from the tank, and it’s dry. I’m not a mechanic, but I’m just trying to gather info on how to help her. Any info would be appreciated. Thank you!
