Seabeeskeane
I brought a 03 Jetta alh 90hp. I needed a fuel injection pump which I replaced with a 10 mm pump didn’t know about the 11mm infill a couple of months later. I’m looking to do a little bit of upgrading but not sure If it’s worth it since it has 220000 miles on it. So far I did a egr delete new timing belt and water pump new control arms dropped it a 1.5inches switch out the air box with a cone and replaced my high pressure fuel lines. I have gear oil for the transmission that I’ll do when it’s warm. Any info will help thank you
