Mdelfunt
Team, I just acquired a 2005 Jetta TDI, 5 speed manual; 188k miles. I'm a Mercedes CDI guy so this is my first VW.
Issue #1
On the way home the AC compressor Control Valve blew out losing the lock retaining ring. I can buy another Valve but I can't find the retaining ring. Anyone know where I can get it or the specifications so I can find a replacement?
Issue #2
When The clutch peddle is NOT pressed, I hear a rattling or knocking noise when idling. Push in the clutch the noise goes away. Everything shifts fine. I've seen some documents that suggest Throwout bearing or Dual Mass Flywheel (DMF), or clutch/PP, or maybe all of them. I read that some are replacing the DMF with a SMF. If I go down the road of replacing stuff, which is preferred? I don't know whether this should be handled with urgency or not. I don't won't to tear up things but not looking for another project immediately.
Thanks guys!
Issue #1
Issue #2
Thanks guys!
