Here is my autoscan from just moments ago:
Monday,15,August,2022,09:12:03:34089
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.3.1.4 (x64)
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: WVWCE63B65E038471 License Plate:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWCE63B65E038471 Mileage: 303470km-188567miles
Address 01: Engine Labels: 038-906-016-BHW.lbl
Part No SW: 038 997 016 T HW: 028 101 198 2
Component: R4 2,0L EDC G000AG 0314
Revision: 12345678 Serial number: VWZ7Z0D0237939
Coding: 0150034
Shop #: WSC 09113 444 89107
VCID: 2F6D2411BD9865F766-515E
VINID: 9E69D35460D21855400C810704CB59F03D
No fault code found.
Readiness: 0 0 1 1 1
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 3B0 927 156 CF
Component: AG5 01V 2.0lPD USA 0404
Coding: 0001104
Shop #: WSC 05311 000 00000
VCID: 6CD7F31D4C0EDEEF03-515E
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
Part No: 3B0 614 111
Component: ABS/ASR 5.3 FRONT D00
Coding: 00011
Shop #: WSC 05314
VCID: 53A548E1A170611722-5140
1 Fault Found:
18034 - Powertrain Data Bus
P1626 - 35-10 - Missing Message from TCU - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 C
Component: 09 AIRBAG VW61 04 0003
Coding: 12345
Shop #: WSC 05311
VCID: 2447DB3DB45ED6AF8B-5124
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 A
Component: Lenkradelektronik 0005
Coding: 00118
Shop #: WSC 05311
VCID: 2F6D2411ED9865F766-515E
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 929 C
Component: KOMBI+WEGFAHRSP VDO V04
Coding: 15235
Shop #: WSC 00000
VCID: 275DCC31C5683DB7AE-5124
WVWCE63B65E038471 VWZ7Z0D0237939
3 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
00779 - Outside Air Temp Sensor (G17)
01315 - Transmission Control Module
49-10 - No Communications - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 05311
VCID: 70EFE76D30263A0F3F-5124
1 Fault Found:
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 80 Komfortgerát HLO 0004
Coding: 00258
Shop #: WSC 05311
VCID: 377D1C7115C8AD373E-4B1C
Subsystem 1 - Part No: 1C1959801
Component: 80 Tõrsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C1959802
Component: 80 Tõrsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811
Component: 80 Tõrsteuer.HL KLO 0202
Subsystem 4 - Part No: 1C0959812
Component: 80 Tõrsteuer.HR KLO 0202
3 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-00 - Implausible Signal
00930 - Locking Module for Central Locking; Rear Left (F222)
27-10 - Implausible Signal - Intermittent
00931 - Locking Module for Central Locking; Rear Right (F223)
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180 G
Component: Radio PM6 0016
Coding: 04031
Shop #: WSC 05311
VCID: 2447DB3DB45ED6AF8B-5140
End-------------------------(Elapsed Time: 04:31)--------------------------
