dieselxj
well imagine that. the brake light comes on and the the brakes need to be serviced. But the story still sucks. Put on a new set of front brake pads. Pretty straight forward, watch a video and look through the FSM for about an hour to find a page that looked correct. make sure there are no hidden tricks in the procedure. Book says always replace the guide pin bolts at pad change. No mention of new bolts in several videos that i watched. So old used guide pin bolts it is. Pads go on no problems put a little light grease on the contact patches for the new pads, torque the old guide pins to 25Nm. Everything looks good. turn on the ignition, no brake warning light, yeah , still looking good. Step on the brake pedal to bring the new pads to bear on the disc, pedal goes to the floor springs back a little, does not go to the floor on the next press down. AND the pedal does not come back up!!!!! Pull the pedal up with my toe, let it sit for a few seconds. press again , good pedal, but not enough return on the pedal to shut off the brake lights. And there it is..... !!! fix one thing and something else breaks straight away. Drain a little fluid out of the master cylinder reservoir, set the level to max. Still good pedal feel , but no return. Go for a drive, still no return. have to pretty much keep the pedal up with my toe or the brakes will start to drag, and i guess the computer senses that and puts the trans in limp. Pick the pedal up with my toe, and drive normally, or normally with my toe under the pedal holding it up.
i think i am done. any one want to buy a 2005 Passat Wagon TDI, No time in the North, no rust, 128000 miles clear Texas title BSM delete, recent transmission, and front axles
