Vwkaferman
Yay! I just about bought this car sight unseen. Every time a Wagon TDi manual came up, it was usually gone the same day. I just happened to be working in LA when this one popped up. I got on the phone with him, sent him $250 via Paypal WHILE on the phone with him. Upon arrival my heart sank a little. Car was SO dirty, inside and out. Lots of little gremlins which I've started to make a list below. BUT, I've gone over the seats a few times, and I think a few more passes in the interior, she's gonna come around.
Owner says it has a Malone Stage IV tune. Upgraded injectors and turbo. I have no paperwork, the car does roll coal (not that I'm trying to do that) and moves out pretty well. I'm just baffled why he would keep the stock exhaust on this car. I mean, the turbo must feel pretty choked up. Definitely want to get a Cat back for it, lol I wonder if I should just go out and cut the muffler off and get a downturn pipe from O'Reilly. Can't sound any worse/or better than my turbo back (straight pipe ) '93 Cummins. Heh.
OK, a couple of pics after the car wash today, cleaned inside and outside windows, degreased engine bay, looks a bunch better. Below pics is my to do list including what's currently on order (ordered today from RockAuto and ECS Tuning)
To do list:
1. Check all 5 tires Air pressure (why I haven't done this yet is beyond me)
2. Repair foggy headlights, buy new down the road
3. Fix saggy headliner
4. Timing Belt/ Coolant Flush/ Water pump, Fuel Filter, Oil and Oil filter (basically whatever service is called out when doing Timing belt)
5. Heater Core likely needs to be swapped out. Doesn't appear to be leaking, but when turned on heater, not a whole lot of heat came out
6. HVAC blend door fix (foam is likely all gone, apply aluminum tape over blend doors, likely removing entire HVAC in order to do this, YAY)
7. Stereo. Have gotten spoiled with rental cars for work having Car Play. Might as well get one capable of back up camera
8. Deep Clean <--in progress
9. Remove Sunroof shield (on top of car, hate the way it looks)
10. New Antenna <--Ordered from RockAuto
11. Driver side brake light <-- Have bulb, waited to get home, looks like I need to remove that foam piece behind the panel to get the bulb board/holder out
12. Brake Flush. A bit spongy
13. Tranny inspection hole cover. <-- I think I found it in the car. Bright yellow, or maybe NYG (as us neon guys say, Nitro Yellow Green)?
14. FMIC (front mount intercooler). If it has a Stage IV tune, I think an intercooler upgrade is in order. I wonder if I can email Malone Tuning and ask if they track VIN's?
15. Air Filter change <--Ordered from ECS Tuning
16. EGR delete?
17. Cat back exhaust
18. Raise rear. It's on Coil-overs, shouldn't be too difficult.
19. New/Used Keyfob as main key, use old one as spare
20. Button for center armrest/console <-- Ordered from Rock Auto
21. Driver door does not activate interior lights. Other doors do. Research shows that the "switch" is integrated into the door latch. "Yay".
22. Euro Headlight switch. Hopefully didn't waste my money on this one. HATED my DRL's on my 96' GTI VR6 I had in Germany. People were ALWAYS flashing me telling me "idiot, it's daytime, your lights are on". Even kids on a schoolbus once were all motioning "your lights are on". The fix back in the day was simply swapping out to the Euro headlight switch so I ordered one from ECS tuning. We'll see.
23. TINT WINDOWS! Holy cow, AZ, you have to have tinted windows.
24. Order windshield shade from Covercraft.
25. Cabin Air filter <-- Ordered from RockAuto
26. Steering column "tilt" handle. This one just flops around. <-- Ordered from ECS Tuning
27. Sunroof Ceiling Control cover. Old one is just coming apart (fabric). I "think" the one I ordered has fabric so should look new. <-- Ordered from ECS Tuning
28. Almost forgot, get it registered here in AZ LOL. Hopefully she passes emissions!
LOL if you've made it down this far, thanks for reading. I've got my work cut out for me, so far loving this car.
James
To do list:
16. EGR delete?
James
