validius
Lacking in ZDDP
fixed!compu_85 said:The right oil will be 5w40. Any diesel oil that meets CI4, 505.00 or better and is of that weight will meet the specs for that engine.
Don't neglect the timing belt!
As a note to Lawson's TDI we did the heater core 2 weeks ago... what a PITA! Ended up having to take the whole dash out.
-Jason
Your best bet would be Mobil1 Turbodiesel truck. While 5w40 Rotella is a great oil that far exceeds the original spec for that engine the Mobil1 is only marginally more expensive and is an even better oil. Mobil1 filter 'M1-301' is the best filter. Avoid cheap filters like Fram as they are only marginally better then no filter at all. With either of the above oils and a quality filter you are safe to change the oil every 7500 miles.
