New to forum,,, Audi A/C issue!
Bigfishn864
Gaffney, SC
2011 Audi A3
This is my first post, so hello everyone! The issue is my AC stopped cooling and before that it was cooling intermittently! I suspect the compressor valve is bad so I order one from Amazon (Rkx) along with the gauges and vacuum pump, but not sure the correct procedure to follow! Any thoughts or directions would be greatly appreciated!
DivineChaos
gets cold here
mk6 jetta sportwagen tdi
First you have to get the freon recovered. Then remove the valve from your air conditioning compressor. Install the new valve. Vacuum the system down noting the pressure. Let it sit for a half an hour to make sure it doesn't increase. Then fill the system with the specified amount of freon.
DivineChaos
gets cold here
The hardest part is getting the valve out. On mine I've had to leave a half a PSI of pressure within the system to aid popping the valve out.
