New TDI swap
Myst69
Pacific Northwest
2.0 BHW
Hello everyone, I’m new here and was hoping for a couple pointers. I recently received a 2005 Passat wagon with a TDI 2.0L automatic with the transmission burnt out and I would like to learn the basics of prep and removal of engine, harness and ecu for the purpose of swapping into a 1992 Jeep Comanche 4x4. Any pointers are welcome and appreciated.
PickleRick
Greenville sc
87 4 runner BHW swap, 2011 A3 tdi, several b5.5 bhw's.
Keep engine harness uncut, de pin from the ECU box. Cut 18 inches from pedal harness plug.
Now make spaghetti!!!!
PickleRick
Greenville sc
No machine work needed. Cam should be inspected. Balance shaft should be deleted if chained.
If you were on the proper coast I'd be talking you into selling me that shell.
You will need to retune the ECU and delete the immobilizer
Myst69
Pacific Northwest
2.0 BHW
Well the shell will be for sale once I get the engine and related components out, clean title etc. I’m sure someone would be interested on here but yes I am located near Tacoma WA
Myst69
Pacific Northwest
2.0 BHW
Removal is underway, I can’t imagine why the transmission went out the oil looked and smelled just like engine oil :oops: I guess these transmissions go out between 200-300k miles without a transmission service lol
PickleRick
Greenville sc
Those transmissions are lucky to make it past 125k without regular service intervals.
Myst69
Pacific Northwest
2.0 BHW
I was meaning to ask about this immo delete, is it necessary if I am planning on using the truck side ignition system? I know this probably sounds really green but I’ve yet to do a swap to such a dissimilar vehicle before and I want all of my facts straight. Thanks for info on this
PickleRick
Greenville sc
When you send the ECU off they will handle all the immob delete. Even if you purchase a diy immob delete stuff she'll still rev hang between gears without a retune, great if you like to grind gears. She needs to be retuned to a manual transmission.
@burpod has started doing tunes, he might be able to help you out. There are a few other active members who provide tunes that I cannot recall the names of so hopefully they'll chime in or others can provide them.
I used Matt Whitbread for my first go around then David at fast forward for my 4Runner build. David provided my custom harness. Not cheap. I had great luck with both. Will try to make my own harness on the next go project
Myst69
Pacific Northwest
2.0 BHW
Thanks for clarifying. I had my eyes on whitbread for some of the mechanical mods, I think ill try my hand with the harness fingers crossed I don’t screw anything up lol. Are there any inputs from a manual transmission that I need to include in the harness (probably not since the ecu is from an auto and there won’t be a tcm) just figured I would ask. Thank you for your insight on this.
Myst69
Pacific Northwest
2.0 BHW
So what’s the best recommendation for a service manual Haynes, Chilton or others? Maybe a VW/Audi factory service manual, tell me what has worked best for you guys. Keep in mind I will mostly be referring to it for the tech specs on the 2.0 TDI BHW. I do have AllData at the shop but I love having the old school paper backup book on hand.
PickleRick
Greenville sc
The BHW is so simple and well documented I wouldn't fool with a manual. For wiring purposes you can request someone share a pin out for you, I used to have it saved on my email but lost it many years ago.
Cam replacement, replacing timing belt, injector removal/reinstall, balance shaft delete, etc all have well documented threads and YouTube videos
J_dude
SK Canada
2003 1.9l “Jedi”
If you are looking to get a paper manual, the Bentley is the one you want.
But you can get all the same info on this forum.
d24tdi
MT
BHW x3, BEW x2, ALH x2, AHU, 1Z, AFB, AKN, BCZ, BDH
Sad to see a clean looking wagon taken apart like this. Bummer you couldn't find a crashed sedan for it!
Myst69
Pacific Northwest
2.0 BHW
I know it’s a shame but hopefully someone shows interest in the body once I’ve pulled what I need. I own other VW/Audi vehicles that have not been molested so please don’t judge me too harshly lol. This has been something I’ve wanted to do for quite some time and the previous owner was days from sending it to the cruncher so at least I grabbed it before then.
Myst69
Pacific Northwest
2.0 BHW
Can someone give me the names of the necessary/critical inputs or sensors for the ecu that should be kept during the swap? I have a pretty good idea I just wanted to be sure I wasn’t missing anything. I would like to keep most of the engine and systems oe on the engine side including a/c, charge piping/w intercooler etc. unless it would provide great benefit not to. Thanks guys
PickleRick
Greenville sc
You don't want to use the Passat intercooler system. An all aluminum with a larger fmic will be far superior and more reliable.
I went with a BRM intake so the charge pipe enters the same side as the turbo, less pipes under the hood. I deleted the ASV and EGR. Find the tuner you're going to use and what emissions if any you need to pass before you decide on deleting anything. I also had the MAF deleted, came with the tune/custom harness.
Im running all the VW accessories including ac compressor in my 87 yota.
Myst69
Pacific Northwest
2.0 BHW
Got the engine pulled and trans separated, engine on the stand. I started labeling all the inputs on the engine side harness, removed all the plugs and pulled the ecu. Disconnected all of the plugs in the bottom of the ecu box so I could remove the engine side harness then went to take a look on the inside where they came in through the firewall and dang theres a ratnest of wires up under the dash. Should I just unbolt the entire contents of the car side harness and pull all of it? (Looks like the data link harness is intricately woven into the center of the mess) it would be nice if I could pull only the engine control and monitoring portion plus a/c out of it but from what I am looking at that might not be possible.
PickleRick
Greenville sc
The AC is a simple 12v + ground. Mine is run off of two 30 amp relays and the factory 87 Toyota light up blue ac button.
The +12 activation switch for both relays runs through a trinary aftermarket sensor that installed in the high pressure line. It will kill the power if pressures drop below about 125 psi or above about 450 psi
One relay controls the ac clutch, the other activates the 12v fan.
No need for any ECU wiring in the ac system with the BHW.
Inside the cab you need about 18 inches of harness up from the throttle pedal.
Then get as much harness as you can from the obd port.
You don't need anything else inside the cab other than pedal unless you want to run the Passat gauge cluster.
Myst69
Pacific Northwest
2.0 BHW
This is some outstanding information, thank you sir. When you say 18” from the pedal do you mean cutting the harness 18” from the pedal or should I just run the length of the pedal wires to the plug? I thought I remember seeing somewhere that the orange plug in the bottom of the ecu tray tied into the pedal, of course, I could be mistaken.
PickleRick
Greenville sc
You'll need a pin out.18 inches of wire is about All you can get before it enters a larger loom of wire you don't need.
PickleRick
Greenville sc
I should note im running the Passat cluster in my set up. No emissions so the asv, EGR and MAF are deleted. I think I'd get better mpg if the MAF was still in there but I'm not a tuner, I wouldn't have deleted that but I wasn't asked my the tuner nor did I request to keep it so it is what it is.
Because of these issues my wiring will vary from yours a bit.
Myst69
Pacific Northwest
2.0 BHW
Well I thought I was going with a Toyota Tacoma but plans change I guess. Couldn’t pass on the price so I ended up with 1991 sorry correction “Jeep” Comanche 4x4 lol
Myst69
Pacific Northwest
2.0 BHW
I pressure washed the engine after letting some degreaser sit on it for awhile, it was pretty caked on. So the engine ran fine it’s whole life and was meticulously lubed and serviced by the dealership the major downside I guess would be that it had exactly 300k miles on it and I need to build it to last another 300k any suggestions would be much appreciated. So far I’m planning on a counter balance shaft delete, new cam and lifters/seats the timing belt was just replaced so I’ll hold on that also whatever block machine work that may be necessary possibly crank and bearings depending on wear and of course new seals all around. Upgrades that I am considering would be a slightly larger turbo that doesn’t spool up quite is fast, egr delete etc etc. thanks for helping me out guys
