New Spice Red 04 TDI Wagon
LG7N
VERMONT
2004 Jetta Wagon BEW
So....new to this particular forum but have been on Vortex for 10 years. Recently I talked my fiancé into her first VW. I’ve owned MK2,3,4 platforms and have owned many MK3s which I love. I built a Surf Green 95 Golf Sport with a VR6 swap a few years ago from a stripped shell. I love that car. However, I have to say that this wagon is ridiculously fun to drive.
I’ll post the entire story because it’s ironic how we acquired it as it was not planned. Well cared for is an understatement and it has a good amount of upgrades I’m still learning about since I know jack about TDIs.
LG7N
VERMONT
A few weeks ago I helped a friend of mine and found him a TDI wagon that was a second owner car in excellent shape. I had never driven a TDI wagon and loved it. Totally stock. Had he not bought it I would have in a heart beat.
About a week later I woke up and happened to look on CL and saw another one in spice red in MA. All maintenance records since new CA/CO car for much of its life. A huge stack of paperwork. Kerma 150 tune, S7 turbo, refurbished head, southbend stg2 clutch, and a bunch of other odds and ends. All the work was done within last 20k also. The guy who owned it was incredibly nice and pretty ocd.
Today I refreshed the whole front end. New FAG wheel bearings, ball joints, control arms, inner outer tie rod assemblies. Did fuel filter, oil filter oil change, oil cooler seals, new shift knob and boot, smoked turns, leather GTI steering wheel, and a few other small items I replaced.
sriracha
2005 Jetta Wagon 5mt, 1982 Rabbit truck (gas)
Nice looking wagon! These mk4 TDI’s are fun to drive. I kinda stumbled upon my wagon, too.
LG7N
VERMONT
2004 Spice Red Volkswagen Jetta GL TDI 1.9L Turbo Diesel Wagon, BEW engine
SERVICE HISTORY:
*Purchased NEW at Gebhardt Automotive in Boulder, CO on 04/29/2004 with 312 miles
on the odometer.
*BG Recall was completed and Radio/CD player was replaced under warrantee at
10,417 miles on 09/30/2004 by McNevin VW Dealer in Berkeley, CA.
*EGR Cooler Valve recall (M6) was performed at 56,728 miles on 09/14/2006 by
Broadway Volkswagen in Oakland, CA
*Brake Light Switch Recall (N4) was performed at 63,107 miles on 05/02/2007 by
*Flushed Hydraulic System with Super Blue on 09/2007 Clutch, LF, RF, LR, RR
*Timing Belt water pump, timing belt tensioner, tensioner roller, and accessory belt was changed at 83,951 miles on 08/13/2008 in CA.
*Glow plug recall (R8) was done at Morong Falmouth VW Dealer in Falmouth ME on
08/06/2009. ECM software was updated per VW Guidelines.
*Oil Pan was replaced with steel insert at 92,376 miles on 12/03/2008
*Windshield replaced 11/10/2009 (several rock chips and a 4” crack from one hit the
lower edge of the windshield).
*110,944 EGR leaks confirmed. Diesel Geek EGR Delete kit installed at 111,012 miles on
01/20/2010.
*Parts replaced on 02/01/2010 @ 111,693: (1) Alternator, (2) Left front ABS and Brake
pad wear sensor wire harness, and (3) ABS Speed Sensor. Codes Cleared.
*RocketChip Stage I+ 2/12/2010 ECU w/ EGR Delete
*Replaced brake pads (front & rear) on xx/xx/2010 at XXX miles.
*Replaced LF wheel hub assembly, wheel bearing, and ball joint on 09/03/2010 at
120,704 miles.
*Bilstein struts and shocks installed with all new mounts and bushings (Replaced RF ball
joint) on 10.07.2010 at 122,387 miles
*Thrust alignment performed on 10/11/2010 at 122,434 miles
*Timing Belt Replaced on 2/4/2013 @ 156,221 miles; Frost Heater installed. Skid plate
installed. Walker VW, Barre, Valve
*Replaced brake pads and rotors (front & rear) on 03/13/2013 at 158,082 miles at The
Source Berlin VT
*NGK 7v Glow plugs installed @180,056
-- - - - - - - - - - - - - - - - - - - Car sold to AM
*New rear pads and rotors. ID parts. @182k 10/2015
*Brakes bled LF, RF, LR, RR with ATE fluid @ 182k
*New parking brake cables (heavy duty) @ 186k
*New signal stalk, front right ABS sensor, headlight bulbs, Dieselgeek short shift kit, first
gear getter and radio repairs @196k
*New rotors and pads, front and rear (weak pedal and very rusted old rotors). ECS
Geomet and Hawk pads, new rear slides, Tyrolsport brake stiffeners on front @201k
*New DMF Clutch kit, Rear Main Seal, Slave cylinder, Transmission oil, Coolant, L and R
CV joint/axles, L and R ball joints at Shaftsbury Auto @203k, 12/12/16
*Turbo replaced with Borg-Warner S7 v.2 from Kerma TDI, new braided steel flexible oil
supply line. Chris at Kerma TDI Ext. 117, labor at Eurozone Motors @ 206k, 2/2017
*Valve cover gasket replaced. New Viton seals on boost pipes in engine bay, boost collar
at intake manifold. EGR valve cleaned @207k miles, 3/2017
*New set of Continental PureContact 2 tires. @207,800, 3/2017. Road Hazard from Tire
Rack, Reference Number(s): 440013310601, 440013310602, 440013310603,
440013310604.
*New pierburg tandem pump, new oil dipstick tube, new turbo oil return line gasket
@215k 8/2017
*South Bend Stage 2 daily clutch, 22lb SMF, new rear crankshaft seal, bolts, etc. New
OEM cam with lifters, bearings, etc., new valve cover w/ gasket, replaced oil cooler
gasket, tandem pump gasket, 3 bar MAP sensor, Kerma TDI tune, new shocks+struts,
alignment, tires rotated. @216,500mi 9/2017 Left Lane Cars, NJ and Walt’s, VT
*RCN-210 radio installed 5/2018
*Front left wheel bearing (whole spindle) replaced, radium catch can installed 6/2018
*Brakes bled 4/2019
235-238K timing belt due
OIL and FILTER CHANGES
All oil changes performed with oil that meets 505.01 specifications at 10,000mi service interval.
4,900 miles on 07/07/2004.
10,564 10/5/2004
20,080 + changed fuel filter, air filter, cabin filter 4/01/05
30,051
40,008 + Changed air filter, fuel filter
48,511 06/24/06
58,000 + Changed fuel filter 11/2006
65,000 + Changed fuel filter cleaned air filter 6/2007
74,400 + Changed fuel filter cabin filter 11/28/2007
82,630 08/02/08
84,100 Fuel filter only changed
92,370 + oil pan 12/3/2008
102,180 + fuel filter
110,944 changed fuel filter
111,400 + air filter and cabin filter (Air filter very dirty) 01/11/2010
122,434 mi
138,200 on 10/22/2011 Changed oil/oil filter/ fuel filter and bled brakes
149,518 on 8/20/12 + air filter/cabin filter and headlight lenses
159,219 on 04/19/13 changed oil/oil filter
168,129 mi
176,453 + fuel filter, air filter
185,200
194,500 + fuel filter
196,200 only air filter and cabin filter (both dirty) 8/2016
202,800 oil/filter, + fuel filter 12/2016
206,900 oil/filter + air filter 2/2017
215,500 oil/filter//fuel filter/air filter 8/2017
216,500 oil flushed twice for new cam 9/2017
221, 450 oil change w/ filter and air filter 11/2017
228,0000 air filter and cabin filter replaced 6/2018
230,500 oil and filter change 9/2018
Car sold to Eli*********
236,000 oil filter (Mann), oil change (Pentosin 5w40 Syn 505.1), fuel filter (Mann), new oil cooler seals top/bottom 5/2019
Fixed charge piping to intercooler that was not seated properly 5/2019
237,000 replaced both front headlight bulbs with correct 9007 basic bulbs, replaced fender turns with smoked lenses DEPO, replaced bumper cover turns with smoked lenses DEPO, replaced dimmer switch OEM VW, replaced entire headlight/wiper stalk assembly with OEM VW, replaced battery holder bracket with clean OEM VW replacement, replaced upper front strut cap covers OEM VW, replaced steering wheel/airbag with OEM VW leather MK4 GTI 3 spoke steering wheel, replaced shift knob and boot with new aftermarket, corrected backward installed license plate light assembly 5/2019
236,300 replaced LF/RF wheel bearings with FAG bearings (hubs were still practically new did not replace), all new control arms/bushings LF/RF, ball joints LF/RF, and complete tie rod assemblies inner/outer with new boots LF/RF with LEMFÖRDER parts from FCP Euro. All torqued to VW specs 5/2019
Fresh alignment 5/2019
Installed 04 Beetele convertible wheels with Goodyear tires 6/2019
LG7N
VERMONT
Was reading about diesel additives. Is it wise to run one all the time or just in winter? I believe the previous owner was running it all the time.
LG7N
VERMONT
Put some 16” Beetle convertible wheels on the wagon. Much better. Got three almost new tires then matched the third one I needed off eBay.
Welcome to the Jetta Wagon world! I can say without reservation it's the best car I've ever owned, and I've had it longer than any other car. Bought new in '02, 389K miles now.
I have other cars, but this is the one I drive 80-90% of the time.
LG7N
VERMONT
That’s a nice looking wagon. Looks to be in fantastic shape. I’m leaning toward getting another one for myself in the near future. I have two other VWs but this thing is literally such a blast to drive. I’m starting to think it’s more fun than my VR6 and FAR more practical.
I’ve been messing with VWs for a long time now and this TDI is just fantastic. I’ve always heard the stories about how awesome they are and now I see why.
LG7N
VERMONT
Wagon has been great! Just put studded snows on, did timing, tensioner, hardware, water pump, cam crank seals, accessory belt, oil change and glow plugs. It got cold and been using the frost heater which is amazing.
LG7N
VERMONT
Got an old school Yakima rack with bike attachments. Issue free through winter. Next I’m going to do a suspension overhaul and brakes.
