New Key FOB won't open trunk
Concat
Edmonton, AB
2005 Jetta GLS TDi
Hi all,
I was sick of the range on my key fobs and replacing the batteries did nothing. I was mentioning to my mechanic that I was going to extend the antenna, and he said not to bother. Just get a new fob on ebay.
So I did that, and followed the process for pairing it to the car by inserting my old key into the ignition, and the new key into the car door.
It worked like a charm, and I got my range back... BUT the trunk button doesn't work. It lights up on the fob, but doesn't open the trunk. Is there a separate process for getting that to work? I do have access to VCDS. To clarify, the key opens the trunk fine, and the button on the driver side door also opens the trunk. It's just the FOB that gets no response.
AnotherPerson
New Orleans
1999 Beetle
I also find the new style remote for my car you have to hold the button longer than the one old.
Wish I would have gotten more than 15ft of range when I got my new one.
Figit090
Northern California
Lifted Unicorn! '03 Jetta GLS TDI Wagon, 5spd, Candy White, Black leather.
What's the normal range? I also noticed on my car the range is somewhat small. Not a huge bummer but I was curious if the batteries were just low?
Where's the receiver antenna?
gavski
NoVA
2002 Jetta TDI GLS 170K
Good mod! Just did this since my dash was half apart already. Super range. Ran out of driveway and it still worked the locks from the house. Sweet.
On my '02, the plugs were a different color. Looking up, it was the one on the left and black, but contained the same clear wire.
Figit090
Northern California
awesome! I'd probably experiment with different lengths so it's not such a huge range (avoid unlocking car from inside Target or somewhere stupid...) but I'm excited.
So does anyone know how long the stock one is? I feel like the location may be part of the issue.. not that I want to reroute it because it's probably difficult to remove from the harness but I'm curious if that's possible.
Good project for a rainy day, though!
Concat
Edmonton, AB
2005 Jetta GLS TDi
Hi all,
Yes I have tried holding down the button for more than 4 seconds, and the previous key fob opened it without issue.
IslandMK5
Vancouver Island
2005 Jetta, 2004 Jetta wagon
Old thread...I know!
Just having same problem.
Ebay FOB, programmed-works great, except no trunk function. Remote lights up, car lights don't.
U4ick
texas
2003 jetta tdi
I,m having this issue with two new Ebay fobs, tried diy method and vcds, can't get the trunk to pop.
Haven't been able to find answer searching......does anybody know anything I can try?
Nero Morg
OR
Do the doors lock/unlock? Could be because it's a cheap chip.
U4ick
texas
2003 jetta tdi
Everything else works except the trunk, on a twenty yr. old car I should just roll on and open the trunk with the key or drivers door switch but noooooo... :confused:
