ericthefish
Hello All-
I have a 2000 golf TDI 5sp with 128k miles, running b100.
6 months ago the car was hard to start (i.e cranking for ~8 seconds before starting up). The dealer did "something" (which I assume was change the timing) and that + a new battery solved my starting problems- it started right up. I had checked the timing last year (i.e. 6 months before taking it to the dealership) and it was fine (right on the midline on the chart). I did NOT check the timing after the dealership did whatever they did, but it sure solved the hard start problem.
I decided to go for some new injectors, so I bought some powerplus 520's from Kerma, then had them installed in bodies at Lubrication specialist.
I put them in 2 weeks ago, and ever since have had a hard start again (~6 seconds of cranking before it kicks in). I asked Greg if he had any ideas, and he suggested checking for air leaks in the fuel lines. All of the fuel lines are pretty tight (I don't have a torque wrench, but they are about as tight as they were to get off). Plus I don't see any fuel leaking around the connections.
I read up on the forums and found that timing is a pretty good suspect for hard (cold) starts. My car never has a problem with warm starts. I checked the timing yesterday and it is off. It was below the shaded range on the chart.
The timing belt was changed around 80k (by the previous owner) so I haven't touched it.
Before I mess with timing (which I have never adjusted before), I wanted to see if the boards have any suggestions on anything else to check/change. I did do the injection quantity adjustment and the EGR recalibration.
My question is: Is it possible for the timing to change? Is there anything in replacing the injectors (following the procedure from TDI club) that could affect it? i.e. all of the cranking to get it started after all of the fuel lines went dry. One question I have is about injector 3, with the sensor in it. I now have a new one of those. Is it possible that my old one was bad and it wasn't sending the signal properly? Or the new one is bad?
Thanks in advance.
--Eric
Thanks in advance.
--Eric
