morty
Car has been very good.
It just turned 80K when I finally got around to installing the Bosch injectors. Everything was clean, I used new washers, etc.
I liked the newfound power, and on a deserted not yet built subdivision I did 3 or 4 accelleration test. I really gunned it, abeit slowly off the line. I managed to pull some black marks even after clutch was fully let out.
OK, so I go for lunch in the afternoon, and I hear this awful noise when accellerating semi-hard. At first I thought clutch chatter. It's only when I get on it. I can run the same rpm *freely* w/o producing this noise.
Then I called Dogbreath (Brian) and he thought I might have popped a hose. I removed the heavy skid plate (wow- that thing has gotten some use) but I couldn't find anything wrong. I do not have access to an air compressor so I couldn't pressurize the intercooler/turbo combo.
I've had my typical share of TDI problems, but I still love the car, and wouldn't trade it for anything except another diesel (hopefully a Toyota Avensis in 06)
Let me describe the noise...
At first it sounded a an exhaust leak.
Then a compression leak...(maybe I didn't tighten the injectors enough)
Now after talking to Dogbreath (thank you) we feel that it might be a blown hose somewhere....only that I can't find it.
The car starts great and runs good. Only under other than meek acceleration does it make this sound.
I should have just gone for the Stage II or III kit from Valois.
Thanks for your help in advance.
Morty
00' Golf TDI
Morty
00' Golf TDI
