Ok, so while all this is happening, I took fuel injectors to local shop to be tested. Results indicate one of the injectors has excessive return volume due to faulty valve. Tech stated that this valve has a dual function:injection and return. So it injects fine, but returns too much..??
Given this, would that explain possibly the reason for the fuel rail pressure too low fault? If so, how? I'm thinking that if fuel is being returned, the result would be high pressure instead of low.Am I thinking this right? Also, would this return be shown in "vcds fuel pump show measuring values"?
Car starts and drives fine for about 15 miles then glow plug starts flashing, car goes into limp mode.
