new fuel leak at injection pump
timscarz55
payson az
02 alh Golf 1.9l tdi
my (‘02 alh) injection pump drips fuel at startup…on injector side. she has 214k miles. Is this indicating pump failure? Not too cold yet here..30* F
P2B
Toronto & Muskoka, Canada
Assuming the hard lines are gutntight, you probably need to replace the pump head seal. Don't leave it too long, there are wires and hoses below the pump head which do not respond well to being soaked in diesel.
JDSwan87
Black Swamp Thing
Michigan near Toledo
2001 Jetta TDI, 5 speed Lagoon Blue Metallic(sold); 2005 Jetta TDI Wagon auto
This is what you need.
Not a hard job, just need to be detailed when you do it. Then check you IQ (injection quantity) with VCDS when done. Very likely you will only need the 2 big seals in the kit.
