NEW Crank Counterhold Tool at Metalnerd.com
Metalnerd
Greensburg, PA, USA
96 Passat TDI Storm Grey
Planning a Front Main Seal Replacement?
Consider our Tool MNKICK-4CYL – Aluminum Economy Grade 4cyl Crank Counterhold
This thick aluminum bar provides the rigid counterhold needed for safe removal and installation of the crank sprocket center bolt. Tool should fit all 4 cylinder water-cooled VW®/Audi® in-line engines that utilize a toothed timing belt. Replaces factory tool #3415. Not for engines with main timing chains. This tool is a more economical alternative to the NuYank-4Cyl. This economy tool is no frills and does NOT have a lifetime warranty. If you want a warranty, order the NuYank-4Cyl. Both are listed on this page http://www.metalnerd.com/cat05.htm.
The two ends of the tool have different hole arrangements to allow you to select where the bar will contact a rigid stop (floor, subframe, etc). Comes with 3 high strength bolts and washers. Impact rated to counterhold your use of impact guns or breaker bars to remove the center bolt. Stable enough to use against your torque wrench and extensions for stretch bolts. Precision machined in USA, Metalnerd® brand. A 19mm, 12-point impact grade socket sold separately.
Shipping is not included in the cart pricing, however, shipping is not free. We calculate shipping and add it to your order total before we process your credit card. If you want a shipping quote make a note in the comments section of the cart and we will provide a quote before we process your order or simply drop us an email. For more information, see our Policies page.
Price: $59.00 and found on this page: http://www.metalnerd.com/cat05.htm
Please email us if directly if you have any questions.
Chuck
info@metalnerd.com
jasonTDI
TDI GURU Vendor , w/Business number
Oregon, WI
20' RAM 3500 CCLB dually HO/Aisan. 2019 Cherokee 2.0T
I would think since thei IS HIS MARKET AUDIENCE the price is the price. Cut the guy a break. Some people always looking for a deal.
kooyajerms
grocery getter
Pomona, Southern California
$123.17 for VW®/Audi® tool #3415. You just saved $64.17
Do you really need to save 5 more dollars?
oldpoopie
Portland Oregon
2001 golf gl, 2006 jetta, 1981 ALH swapped rabbit pickup, 1998 beetle
Ive used it. Works like a champ.
As usual a quality product from Metalnerd!
