Sbeghan
All right, I'm convinced. Frank, you'll have a set of those nozzles in a year when I have money and get chipped and swap my nozzles and IP? If not, make sure to hold me a set
Hey guys, newbie here, although have been lurking for about a year... 5 months ago, got my 1st TDI, a 2003 New Beetle GLS 5spd. LOVE the car, but would like a bit more power. Would like to upgrade nozzles 1st, due to the fact that my original nozzles (stock) have 142,000 miles on them and are probably nearing the end of their useful life. Possibly tune later.Of the ones of these I have installed, only an IQ tweaking was needed. <snip...> they have all been otherwise stock 5sp ALHs. <big snip>.
Thanks for the info and good advice, M_T! I wussed out on the T4's for now and for my temporary fix, I ordered a set of Sprints (I know...) from BleachedBora (nozzles only). Clutch has < 30k miles on it, but was able to speak to PO's mechanic today. Mechanic told me it was a NAPA replacement clutch and he did not touch the original DMF. So, I decided to err on the side of caution, and take your advice on the clutch.I'd still get T4's, but perhaps stick with a very light tune like RC1 if you don't want to buy a new clutch. <snip>
I should have mentioned that it is a good idea to do early maintenance before you begin modifying to ensure that everything is working correctly to begin with... <snip>
I agree with Wingnut, T4's and a stock tune you will get a little smoke but not much more than stock nozzles.You can keep your fuel economy and run without smoke if you get tuned right. In order to keep you smoke free with T4 injectors, you'll need a new clutch and a RC3 tune (or equivalent). axles and a lowered compression ratio, not to mention new tires.![]()
Again no need for a clutch first. I recommend to my customers all the time to get new nozzles and have their injectors rebuilt and pop tested before they do anything else. Its better to have the engine performing at optimum than to have a stronger clutch or a tune installed.manual_tranny said:I'd recommend that you first install and break in a clutch (Get one much stronger than you want to go because you will soon be addicted adding power!) ... then find a GTG with a tuner that can give you RC3 or equivalent.
No worries! It does turn out that schwarze Käfer has a NAPA clutch, and I'm not sure how many ft/lbs they hold, but perhaps a 1.5 tune with T4s would be asking a lot of it. Maybe not. I do know I need a new clutch to hold the T4s and the RC2 tune as my clutch started slipping the first time I tried full throttle in 5th gear. Shwarze sounded like he wanted a pretty noticeable gain in power, and now he's stated his final goals are a minimum of 150hp. I'll bet he'll need a clutch before long...I agree with Wingnut, T4's and a stock tune you will get a little smoke but not much more than stock nozzles.![]()
Sorry to disagree with you manual_tranny, but there is absolutely no need for a new clutch with T4's, or T4's + tune. I tune customers cars with a Malone Stage 1.5 "Clutch Saver" tune fairly often with T4's. Stage 1.5 is a nice smoke free tune, gives you an extra 32 HP, but limits your torque to 34 ft lbs. By doing this you can run with a stock clutch for a long time with no issues. No need for axles or lowered compression ratio.
No offense taken, I mostly agree!Again no need for a clutch first. I recommend to my customers all the time to get new nozzles and have their injectors rebuilt and pop tested before they do anything else. Its better to have the engine performing at optimum than to have a stronger clutch or a tune installed.
Hope I have not offended you manual_tranny, just sharing my first hand experience.
Cheers
Yeah if you have a RC2 + T4's then your stock clutch will slip.No worries! It does turn out that schwarze Käfer has a NAPA clutch, and I'm not sure how many ft/lbs they hold, but perhaps a 1.5 tune with T4s would be asking a lot of it. Maybe not. I do know I need a new clutch to hold the T4s and the RC2 tune as my clutch started slipping the first time I tried full throttle in 5th gear.
I want to be in Nirvana too!Thanks, Chuck. I will keep you guys at Dubwerx in mind for my Cinnci customers' head work.
The T-4's are fun, eh? If I can get the next size up, you'll be in Nirvana.
