calimustang
- Joined
- May 17, 2010
- Location
- Central FL
- TDI
- 2011 JSW DSG (buyback, RIP), 2014 JSW TDI, 2015 Passat TDI, 2013 Jetta TDI.
Hello,
been trying to get this resolved for a week and half, I am exhausted. also engine fans doesnt engage at all. it started to act like this right before cheap vw oem battery went. then placed a correct oem vw battery, everything goes like shown below, (I took out some of no fault on VCDS to reduce the post size)
I did clear them all and unplugged battery for a hour. no luck. she did drop speed and speedo went to 0 acting like transmission went into neutral then catches on at 25 mph rolling and speedo goes back to 25 like if it didnt happen. made me nervous.
almost same issues with my 2015 vw passat but drivability is fine, slight stumbles then goes. will post passat on other thread.
scanned off my VCDS,
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN: 3VWPL7AJ9EM621597 Mileage: 129740km-80616miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 E HW: 03L 907 309 AA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H16--- Serial number:
Coding: 0050078
Shop #: WSC 74291 008 00000
VCID: 306F63CDA3A65606A3-8064
No fault code found.
Readiness: 0 0 0 X X
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 062 B HW: 02E 927 770 AL
Component: GSG DSG AG6 521 9430
Revision: 05652104 Serial number: 00001403032138
Coding: 0000024
Shop #: WSC 01286 386 08256
VCID: 1427CF5D37FE8A26A7-8040
1 Fault Found:
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 1
Mileage: 129747 km
Time Indication: 0
Date: 2015.03.01
Time: 00:01:44
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM
Component: ESP MK60EC1 H46 0164
Revision: 00H46001
Coding: 114B600C492400FB881006ED92200042A1000022
Shop #: WSC 00066 790 00013
VCID: 7EF38DF5E972707661-802A
3 Faults Found:
00285 - ABS Wheel Speed Sensor; Front Right (G45)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 231
Mileage: 129746 km
Time Indication: 0
Date: 2015.03.01
Time: 23:46:04
Freeze Frame:
Count: 3
Count: 12
Count: 20480
Count: 56
Count: 44032
Count: 0
Count: 256
Count: 0
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 231
Mileage: 129746 km
Time Indication: 0
Date: 2015.03.01
Time: 23:46:04
Freeze Frame:
Count: 3
Count: 12
Count: 20480
Count: 16390
Count: 44032
Count: 0
Count: 256
Count: 0
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 231
Mileage: 129747 km
Time Indication: 0
Date: 2015.03.01
Time: 00:01:43
Freeze Frame:
Count: 3
Count: 12
Count: 20480
Count: 128
Count: 43520
Count: 1
Count: 512
Count: 0
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 N HW: 5K0 937 084 L
Component: BCM PQ35 B 122 1184
Revision: BG122001
Coding: AF380E1A802F3EC4008800C17000004449000086535D0520648020200040
Shop #: WSC 00728 003 1048576
VCID: 3D714AF9A4F4AB6E38-8068
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 05051 26 0512
Coding: 009795
1 Fault Found:
00987 - Lamp for Brake Light; Left (M9)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 231
Mileage: 129747 km
Time Indication: 0
Date: 2015.03.01
Time: 00:01:43
Freeze Frame:
Term 15 On
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 70 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 39795EE970DC974E14-806C
2 Faults Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 16
Mileage: 129746 km
Time Indication: 0
Date: 2015.03.01
Time: 23:46:04
Freeze Frame:
Voltage: 12.38 V
DD
Temperature: 29.0°C
RPM: 0 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
03803 - Steering Angle Sensor for Steering Aid
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Battery Volts: 12.5 V
PD
Temperature: 27.0°C
Count: 2
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Coding: 0050078
Coding: 0000024
1 Fault Found:
P1847 - 000 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 1
Mileage: 129747 km
Time Indication: 0
Date: 2015.03.01
Time: 00:01:44
Revision: 00H46001
3 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 231
Mileage: 129746 km
Time Indication: 0
Date: 2015.03.01
Time: 23:46:04
Freeze Frame:
Count: 3
Count: 12
Count: 20480
Count: 56
Count: 44032
Count: 0
Count: 256
Count: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 231
Mileage: 129746 km
Time Indication: 0
Date: 2015.03.01
Time: 23:46:04
Freeze Frame:
Count: 3
Count: 12
Count: 20480
Count: 16390
Count: 44032
Count: 0
Count: 256
Count: 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 231
Mileage: 129747 km
Time Indication: 0
Date: 2015.03.01
Time: 00:01:43
Freeze Frame:
Count: 3
Count: 12
Count: 20480
Count: 128
Count: 43520
Count: 1
Count: 512
Count: 0
Revision: BG122001
Coding: 009795
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 231
Mileage: 129747 km
Time Indication: 0
Date: 2015.03.01
Time: 00:01:43
Freeze Frame:
Term 15 On
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
Revision: 00H22000
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 16
Mileage: 129746 km
Time Indication: 0
Date: 2015.03.01
Time: 23:46:04
Freeze Frame:
Voltage: 12.38 V
DD
Temperature: 29.0°C
RPM: 0 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
PD
Temperature: 27.0°C
Count: 2
Count: 1
SteerAng n.Init
