new battery installed and xmas lights on dash (stubbornly)
calimustang
Central FL
2011 JSW DSG (buyback, RIP), 2015 Passat TDI SE, 2014 JSW TDI.
Hello,
been trying to get this resolved for a week and half, I am exhausted. also engine fans doesnt engage at all. it started to act like this right before cheap vw oem battery went. then placed a correct oem vw battery, everything goes like shown below, (I took out some of no fault on VCDS to reduce the post size)
I did clear them all and unplugged battery for a hour. no luck. she did drop speed and speedo went to 0 acting like transmission went into neutral then catches on at 25 mph rolling and speedo goes back to 25 like if it didnt happen. made me nervous.
almost same issues with my 2015 vw passat but drivability is fine, slight stumbles then goes. will post passat on other thread.
scanned off my VCDS,
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN: 3VWPL7AJ9EM621597 Mileage: 129740km-80616miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 E HW: 03L 907 309 AA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H16--- Serial number:
Coding: 0050078
Shop #: WSC 74291 008 00000
VCID: 306F63CDA3A65606A3-8064
No fault code found.
Readiness: 0 0 0 X X
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 062 B HW: 02E 927 770 AL
Component: GSG DSG AG6 521 9430
Revision: 05652104 Serial number: 00001403032138
Coding: 0000024
Shop #: WSC 01286 386 08256
VCID: 1427CF5D37FE8A26A7-8040
1 Fault Found:
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 1
Mileage: 129747 km
Time Indication: 0
Date: 2015.03.01
Time: 00:01:44
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM
Component: ESP MK60EC1 H46 0164
Revision: 00H46001
Coding: 114B600C492400FB881006ED92200042A1000022
Shop #: WSC 00066 790 00013
VCID: 7EF38DF5E972707661-802A
3 Faults Found:
00285 - ABS Wheel Speed Sensor; Front Right (G45)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 231
Mileage: 129746 km
Time Indication: 0
Date: 2015.03.01
Time: 23:46:04
Freeze Frame:
Count: 3
Count: 12
Count: 20480
Count: 56
Count: 44032
Count: 0
Count: 256
Count: 0
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 231
Mileage: 129746 km
Time Indication: 0
Date: 2015.03.01
Time: 23:46:04
Freeze Frame:
Count: 3
Count: 12
Count: 20480
Count: 16390
Count: 44032
Count: 0
Count: 256
Count: 0
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 231
Mileage: 129747 km
Time Indication: 0
Date: 2015.03.01
Time: 00:01:43
Freeze Frame:
Count: 3
Count: 12
Count: 20480
Count: 128
Count: 43520
Count: 1
Count: 512
Count: 0
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 N HW: 5K0 937 084 L
Component: BCM PQ35 B 122 1184
Revision: BG122001
Coding: AF380E1A802F3EC4008800C17000004449000086535D0520648020200040
Shop #: WSC 00728 003 1048576
VCID: 3D714AF9A4F4AB6E38-8068
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 05051 26 0512
Coding: 009795
1 Fault Found:
00987 - Lamp for Brake Light; Left (M9)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 231
Mileage: 129747 km
Time Indication: 0
Date: 2015.03.01
Time: 00:01:43
Freeze Frame:
Term 15 On
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 70 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 39795EE970DC974E14-806C
2 Faults Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 16
Mileage: 129746 km
Time Indication: 0
Date: 2015.03.01
Time: 23:46:04
Freeze Frame:
Voltage: 12.38 V
DD
Temperature: 29.0°C
RPM: 0 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
03803 - Steering Angle Sensor for Steering Aid
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Battery Volts: 12.5 V
PD
Temperature: 27.0°C
Count: 2
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
calimustang
Central FL
keep in mind... I never have this issue in my old 2011 JSW... 3 batteries and drive away, all lights goes off after 1 mile.
calimustang
Central FL
Yep been looking around and you are most likely correct on this. I will buy the main fuse link on Monday. I was too late for today. :) many thanks! Will keep you posted.
mishkaya
TDIClub Contributor
Iowa
'06 Jetta 5MT, '10 JSW MT, '14 JSW 6MT
Just to add another data point; when I had a terminal 30 lower limit exceeded, I tried replacing the main fuse (terminal 30), but it did not fix my issue. Replacing the main fuse box did fix the issue however, even though the fuse box was not part of the recall list...
calimustang
Central FL
Yikes! How did that happen to you?
mishkaya
TDIClub Contributor
Iowa
Not sure what the root cause was, I have a thread on the topic in the MkVI forum. Took me quite a while to get to the bottom of the problem...
Good luck with your issue. I am assuming you have checked and cleaned the grounds thoroughly. That is usually the root cause of most electrical issues.
calimustang
Central FL
Awesome thank you for the info. Will try main fuse link then box if it dont solve that.
calimustang
Central FL
Its the danged main fuse! Lol its almost all gone of codes. Only one code is unable to communicate with abs I think but only vcds. No lights on the dash. Did clear code twice. Old fuse was showing corrosion and connectors were building corrosion. Cleaned them all. Posts look good.
mishkaya
TDIClub Contributor
Iowa
Glad to hear it worked for you. The main fuse is a relatively easy fix. (y)
calimustang
Central FL
Yep just in case if others face same issue, heres the part # 1K0937629A
calimustang
Central FL
yep......... I caught it! dash lights came back. so I plugged the VCDS on. I ran mea block 001 and caught G45 sensor jumpy to 250-300-15-0 for several seconds. so yea.... its shot to hell. just ordered sensors for both cars, arriving tomorrow. hopefully that will end our headaches.
Address 03: ABS Brakes Labels: 1K0- 907-379-60EC 1F.CLB
Control Module Part Number: 1K0 907 379 BM HW: 1K0 907 379 BM
Component and/or Version: ESP MK60EC1 H46 0164
Software Coding: 114B600C492400FB881006ED92200042A1000022
Work Shop Code: WSC 00066 790 00013
3 Faults Found:
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 17
Mileage: 129750 km
Time Indication: 0
Date: 2015.03.09
Time: 02:50:22
Freeze Frame:
Count: 1088
Count: 0
Count: 4608
Count: 51
Count: 50201
Count: 65274
Count: 65534
Count: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 232
Mileage: 129750 km
Time Indication: 0
Date: 2015.03.09
Time: 02:49:14
Freeze Frame:
Count: 16387
Count: 4
Count: 12800
Count: 16390
Count: 50438
Count: 54042
Count: 64251
Count: 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 232
Mileage: 129750 km
Time Indication: 0
Date: 2015.03.09
Time: 02:49:04
Freeze Frame:
Count: 16384
Count: 4
Count: 12800
Count: 48
Count: 50176
Count: 0
Count: 507
Count: 0
Address 03: DTCs cleared
calimustang
Central FL
ok... did some excessive drain out of DSG with leveler in place spot on. test drove her and stomp the pedal to drive the snot outta her for sitting 2+ weeks and punishing her for giving me a headache.
codes went away but earlier this afternoon I did live scan, right front abs sensor jumped from 0-200-250-15 then 0. then did dsg drain then drove her hard. codes went away...........
Friday,16,October,2020,20:02:14:34053
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.2.0 (x64)
Data version: 20200730 DS317.0
www.Ross-Tech.com
Mileage: 129760km-80629mi Repair Order:
Mileage: 129760km-80629miles
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Coding: 0050078
Coding: 0000024
Address 03: ABS Brakes (J104) Labels:. 1K0- 907-379-60EC 1F.clb
Revision: 00H46001
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 CA HW: 7N0 907 426 CA
Component: AC Manuell H20 0606
Revision: 00001002
Coding: 0010002002
Shop #: WSC 00066 000 00119
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 75E192D9D444332E30-8020
Revision: BG122001
Coding: 009795
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 M HW: 5C0 959 655 M
Component: AirbagVW10G 014 0726
Serial number: 003L4R031JXP
Coding: 00004E42
ASAM Dataset: EV_AirbaVW10SMEVW360 001026
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3C7747FDB7EEA2660F-8068
Seat occupied recognition:
Subsystem 1 - Part No SW: 1KM 959 339 B HW: 1KM 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--0000AH1R00
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME6C1A1C42ZZZ+
Crash sensor for side airbag: front passenger side:
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME6A1A1C42ZZZ/
Crash sensor for side airbag: rear: driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME052B3830ZZZD
Crash sensor for side airbag: rear: passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME0F1A3830ZZZM
Crash sensor for front airbag: driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME38723C30ZZZE
Crash sensor for front airbag: front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME56244630ZZZ7
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0090
Revision: -------- Serial number: 90422NCI000KY
Coding: 188A140000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76E395D5C942383639-8022
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Serial number: 0300182 FLE 20140311
Coding: 820000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K0 920 973 G HW: 5K0 920 973 G
Component: KOMBI H04 0811
Serial number: 00000000000000
Coding: 270F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04721
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 356152D994C4732EF0-8060
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AK HW: 7N0 907 530 AK
Component: J533 Gateway H57 1642
Revision: H57 Serial number: 30041403000171
Coding: 352002
VCID: 79F99EE9F05C574E54-802C
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 002 0002
Revision: 00002000 Serial number: 1225223RPWTF07
Coding: 0000002
VCID: 7EF38DF52972707661-802A
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0811
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
VCID: 6ADBB1A58DFAECD6AD-803E
Address 2E: Media Player 3
Cannot be reached
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0008318034
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW36.rod
VCID: 5BB5E46152A0855E26-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 009 1509
Serial number: 00000008614476
Coding: 000490
Revision: 00H22000
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0008278666
Coding: 0004B4
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW36.rod
VCID: 5CB7E77D57AE82662F-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 009 1509
Serial number: 00000008593014
Coding: 000490
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 188 F HW: 1K0 035 188 F
Component: Radio Prem-8 H07 0009
Revision: -----12S Serial number: VWZ4Z7P3564198
Coding: 01000440040007
Shop #: WSC 00066 000 00000
VCID: 2B5574A14A8035DE96-807E
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 234
Mileage: 129761 km
Time Indication: 0
Date: 2015.03.09
Time: 06:56:26
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0592
Revision: 1B001001 Serial number: 00007666007189
Coding: 0A10030080010110
ASAM Dataset: EV_UHVUMI 001007
ROD: EV_UHVUMI.rod
VCID: 2E537DB5719240F6B1-807A
End-------------------------(Elapsed Time: 03:15)--------------------------
pedroYUL
MI, USA
To the OP...Man didn't the same thing happen to your Passat? Maybe you have a localized EMP go off in your garage
calimustang
Central FL
Lmao!!!!! Thats what I am starting to suspect. ;) Passat is now fixed. Will post the result.
