OK, so you DIDN'T read my post. The VR5 engine, in both 2.3L and 2.5L trim, has been around now for about 8 years. This is a carryover engine...it is NOT new, just new to the US. It uses the EXACT same timing chain arrangement as the VR6, which we have had in 24 valve trim for a few years, and have had in 12 valve trim since the early '90s. So, any issues that those engines have had this "new" 5 cylinder will have as well. Follow me? It is not a new engine, it is an old engine in a new car that is offered for the first time on our shores.
My reasoning stands: if you plan on driving a car for a very long time, a belt driven OHC arrangement makes more sense. If you drive a car to 150k miles and toss it, then a chain is just fine so long as you don't mind the other cons with a chain setup (noise, weight, cost, etc.).
Fact is, timing chains, especially long ones on an OHC engine, are by no means "lifetime maintenance free items" just because it has no mention in the maintenance booklet in the owner's manual. They do wear out, and they are frightfully expensive to replace. The the VR5/6 engines, especially the 4-valve-per-cylinder variety, have an extrememly complex convoluted albatross of a timing chain arrangement using multiple chains, an intermediate shaft, several guides, tensioners, rollers, etc. Plus it is mounted on the flywheel end of the engine!
