Benjamis
I have been getting random misfires for over a year. I replaced relay 109 and then I didn't notice any misfires for the rest of the summer and over 1,000 miles, but as soon as temperatures started to drop, started getting the misfires again and longer crank times and tons of smoke on startup. Found out the glow plug relay stopped working thanks to output tests in VCDS. Put in new glow plug relay and tested each glow plug through the glow plug harness, and they all light up. Had a new backup set and put them in anyway and will save old ones as backup. So glow plugs are good. Timing is mechanically and dynamically in spec. No error codes in regard to the misfires, checked with VCDS numerous times for a year. Finally I left the engine running and went around wiggling wires trying to make it misfire. Never figured it out, but realized when I wiggle the needle lift sensor wire, that there is a humming sound. The humming can be heard with engine off and ignition on, and it comes from the N75 and QA, which is slightly frightening, but only when the connection to the G80 is interrupted. Finally got the P00542 code, cleared it, and it immediately came back on. Checked the resistence across the two terminals of the G80 plug with ignition off, and resistance was 93 ohms, within the 80-120 spec. Doodled around on other things for a minute, then checked it again and resistance was infinite. Found out if I wiggle the wire, resistance fluctuates between in spec and infinity. Isolated it to where the wire enters the injector. The black wire sheath was in excellent condition, no chaffage. Cut off the black sheath to expose the two white wires, and one white wire was severed.
Anyone ever have this happen?
Yesterday, I cracked all 4 injectors with engine running and they all make the engine sputter, meaning they all work properly right? However the injectors are of unknown age, and obviously old enough for a wire to cut itself off inside of a sheath. I have had this car for 4 years, 30k miles. I actually removed and took apart the injectors 2 years ago and cleaned them all up and checked the spray patterns and all seemed good. Only thing was #4 injector had a few rust spots on some of the internal parts, which was surprising. Would love to buy a whole new set of injectors, but the price tag is rather uninviting. What would you do, buy a new #3 and new nozzles? Would you buy a new #4 too, or all new? Or you have a trick to fix this?
Hoping to clear up the cold start smoke. I have always had a small cloud on startup when it is not summer hot. Kind of embarrassing.
