Andyinchville1
Hi All,
I have been noticing a slight decrease in the coolant ball for the last 50K or so miles ... not a lot but noticeable and concerning ( as in head gasket concerning BUT the oil analysis always came back good in that regards BUT I have not done one for this oil change yet).
Anyways, I filled the coolant system from the low line level on the ball back to the top fill line on the ball and notice after about 50 K it is back to the lower line again.... so something is happening but luckily over a fair amount of time and miles
Upon closer examination of everything , I saw my first "wet spot" (not even a drip just wet to the point where you rub your finger on it it is wet) coming from the upper radiator by the plastic connector piece with the small hose attached to it .... the part of the hose that was slightly "wet" was the hose section near the clamp closest to the engine on the upper radiator hose (on the plastic side NOT the
side by the engine and coolant glow plugs).
I thought about just replacing the plastic upper radiator connector piece and that section of upper radiator hose and clamps BUT then I was thinking paranoid thoughts and (like shocks etc) maybe things should be replaced in sets since when one goes maybe the others are not far behind.
What is the typical wisdom on just replacing everything when it comes to coolant hoses VS just replacing the offending pieces ?
How long do or should radiator / coolant hoses last ?
What are some good brands and sources for these hoses ?
I am thinking an entire kit with everything would be best / easiest and I have heard that silicone hoses (like used in police cars / cabs) are possible even better than "regular" rubber hoses . Any ideas / sources on the silicone hoses?
FWIW my other hoses look and feel OK (hard / firm not squishy or bulging .... but interestingly the one that is "bad" looks good too BUT maybe JUST the plastic piece went "bad" (like small crack etc)..... UNLESS the slight leakage somehow erodes the rubber in such a way that even IF it is the plastic piece is causing the issue it has eroded the rubber also requiring its replacement ? OR , If it is just the plastic piece that is bad can the hose simply be replaced?
I admit I am leaning towards replacing everything hose hose wise since the car is 18 years and 439K miles old .....
What are your thoughts and experiences ?
I am thinking about this kit BUT is does NOT seem to include heater hoses ? .... Are the brands used in the kit decent ? ... I don't really need the radiator BUT maybe I can keep it in case I hit a deer OR maybe sell it OR just change it out because its old too ?
See link :
I LIKE the lifetime warranty on everything they sell so if I do get it from there no more parts costs ever ... just labor and that could be nice piece of mind.
Anyways, hoping to do this ASAP because now I know about the issue and want to get it resolved before driving the car too much more ....
Actually that is a good question too .... would you drive or continue driving it as it is ? ( I had been driving it no issues but was peeking under the hood look at stuff in general (mainly for modding) so had I NOT seen it I would have driven it anyways .... BUT sometimes KNOWING can be an in issue too).
Thanks in advance for any and all help.
Andrew
See link :
VW Cooling System Kit - Nissens KIT-1J0121253ADKT10
www.fcpeuro.com
Andrew
