Need some SERIOUS expert help
smketrny
Orange County, New York
1998 Jetta TDi, 2015 Passat TDi
Greetings, all. Hope all is well. 98 Jetta AHU 255k. Mechanic has had car for too long and can't get it to run. Started with the P1550 code (which was cleared). Found a few wiring issues, fixed. However car will crank but not start. When in pre ignition no lights come on in the panel but the damned clock. Wiring is good according to him. But seems to be stumped on why it wont start. New FSU in the tank. Giles pump with under 5k with rebuilt injectors by him as well. Guys been apologetic because its my beater back and forth to NYC. ANYTHING u may know and can share would be greatly appreciated. Thank you in advance.
hskrdu
Maryland and New England
How good is your mechanic with TDIs?
Mike Hevner is just outside Port Jervis.
smketrny
He was recommended by a Mk4 guy. But hes stumped on this. So anything he can look for would be appreciated. If the suggestions dont work, ill have to haul it to mike. TY
garciapiano
Southern California
1997 Jetta TDI (1Z)
Possibly. If there are no dash lights, that may indicate either that the main power relay 109 maybe bad or the ignition switch. Since it’s much easier and cheaper to replace that relay, I would try that first.
smketrny
IIRC they may have replaced the 109. i will have to call the, tomorrow and verify. Again, TYVM
hskrdu
If you wamt to troubleshoot yourself, we have a whole thread on NSCs (no start conditions):
smketrny
TYVM, but ill admit with the advance in social media, i forgot about this site. I will check it out. Again thank you.
These cars are so simple with regards to engine management, and need so little to actually run (especially a '98).
Here is what I would do:
Connect a scan tool, access the Engine controller (with the key on, you should be able to communicate with it.... if not... you have a problem)
Assuming you can connect, go to the engine data, and find a block that shows engine RPM.... then watch that while you crank the engine. If the value goes up, and shows cranking RPM (whatever that may be... 200-400 ?), then at least you know these two important things: the ECU is "alive" while cranking, and it "sees" the engine cranking. This is a VERY simple step to take.
If the ECU is not staying live during any of this, then you need to find out why. If it does stay live, but you see no cranking RPM, you need to find out why.
Pretty much everything else is simple mechanical old fashioned VE pump diesel. A stop solenoid on the pump. ON = engine runs, OFF = engine not run.
Ignition switches were common failure items on these cars, and often the ignition switch would lose the "run" contacts while in the "crank" position. So if you have the ECU working, the data up, and when you go to crank the car the scan tool suddenly loses communication with the ECU, then that is a good sign the ignition switch is bad.
Warning: tearing the steering column apart to replace the ignition switch is not a big deal, BUT, unlike most cars (including all newer VAG products), the A3's clock spring for the airbag is not attached to the column switches... it is attached to the bottom of the steering wheel..... you need to unplug the clockspring connector BEFORE you remove the steering wheel, or you'll break the clockspring to pieces and you'll have an extra expense to deal with.
smketrny
Oilhammer, you are the man, THANK YOU. I will copy this and send it their way. And many thanks to everyone else (hkskerdu. garciapiano). I will also copy the troubleshooting page hskrdu mentioned as well. One question, tho. If no communication with scan tool, WHAT would that problem possibly be? TY Hopefully I can get this back to my commuter car. Hate using the 2015 Passat and my 07 Dodge Cummins (fuels killing me). Again, thank you to all and any more info/suggestions ARE appreciated. Stay safe, stay well.
Mongler98
Northern MD (HAGERBUSH)
The
98 AHU jetta has no lift pump.
So whatever was put in there is an upgrade when you go massive Injection.
Check ground connection at the round harness at the head. It must be bolted down.
Relay 195 is also suspect
Ignition switch and IP harness. Check and make sure that it's good
smketrny
The
Was aware of no lift pump, TY. But I will forward your ideas as well. Its my little rustbucket but runs (or ran...lol) like a top. Thanks much. Stay safe, stay well, Jimmy
smketrny
Wouldn't hurt to pop open the ECU and make sure both chips are still fully seated.
If the above suggestions do not work, I will send them this as well. Hell, maybe ill just send it. Thanks much Was gong to send the ECU to Malone over the summer while on vacation, they screwed that up....
