J.P.
- Joined
- Aug 14, 2007
- Location
- Northern MI
- TDI
- Black 05 b5.5V/6spd w/274k miles (daily). Silver 02 Golf/5spd w/240k miles (fun 1). Mint Tornado Red 01 Golf/5spd w/440k (ALH still perfect!!!).
UPDATE TO THIS THREAD SO YOU DON'T HAVE TO READ THE WHOLE THING TO KNOW HOW IT WAS RESOLVED:
I ran out of time / patience / ideas for solving clouds of grey smoke on cold start, and had the car tuned. NO MORE CLOUDS OF GREY SMOKE ON COLD START. The tune deleted the MAF, and EGR (EGR was left in place).
ORIGINAL POST
I need some expert eyes help me diagnose a grey smoke issue. I have searched tons of threads on similar issues, but can't seem to pinpoint mine. Here's the story:
New to us 01 Golf with 396k mile. One owner (tdi clubber) meticulously maintained miles. Bone stock with EGR still intact. Drove perfect for us for 2,000 miles. Now it is producing a giant cloud of grey smoke on startup. To me it is grey, it might be considered blue to others. UPDATE: To me it smells like oil, not diesel. Here's what I know / have done:
On cold start (no glow plugs) it now cranks for about 3 compression cycles before it fires, then is rough and stumbly for a bit. It produces a GIANT cloud of grey smoke. Passers by comment, I hang my head in shame.
It used to fire quickly. If I disconnect the coolant temp sensor and force glow plugs it fires right away and there is less smoke (still seems smokey though)
If I start it and keep it parked at low revs until the engine is fully up to temperature it continues to produce grey smoke. (rpms always below 2500)
If I start and drive it, smoke is visible through the rear view mirror on acceleration, or with rpms at 1200 or so. This continues until it is fully up to temp (normal rpms for driving, shifting at 3k regularly)
Removed pancake pipe a day after the idle to temp test. Intercooler is clean, no oil drained out.
UPDATE: Ran the engine with the pancake pipe off. No oil coming from the boost hose from the turbo.
Look at timing via VCDS. Right on the blue line when engine is both cold and warm. Graph says timing is within spec.
Look at measuring block group 04. Start of injection specified vs actual. 0.4 BTDC vs 0.7 BTDC.
Look at measuring block group 13 for IQ balance. 0.78, 0.56, -1.20, -0.14. Not great. Injector #3 is pretty far out of spec. IS THIS ENOUGH TO CAUSE THIS MUCH SMOKE?
Compression test when warm. All values were very close. 460, 460, 440, 460 (and 450 on #1 again) (HF gauge and 50A charger on battery). I haven't done a cold compression test yet.
Logged meas blocks 03, 04, 05 during the warm up cycle, and did the same with our 02 Golf. However the 02 has EGR delete and a tune so they were not an apples to apples comparison and I could not detect something way out of spec. WHAT DO I NEED TO LOOK AT HERE?
Recent new air filter, snow screen cleaned, fuel filter filled with diesel purge.
Recent new CCV and grommets due to a lot of external leakage. Recent new gaskets on oil cooler due to a lot of external leakage. I can't speak to oil consumption because these leaks were pretty significant, and I haven't driven it more than 100 miles since they were fixed.
Recent CEL for "valve for intake manifold flap". It had the wiring worn through due to the corrugated plastic wiring cover (common issue). Spliced in new wiring. No more codes.
What do you experienced tdi guys think this is pointing to? What else do I need to do to diagnose it?
Thanks!
JP
ORIGINAL POST
Thanks!
JP
