Need some help sorting out a bunch of DTCs
Acomp89
Maryland
2013 Sportwagen
This is my first post after lurking for many years, it feels fitting that i am posting with a problem lol. I recently installed a down pipe and a malone tune on my 2013 sportwagen and while it runs great, I now have a bunch of dash lights(ABS, Trac control, Tire pressure, Steering) and quite a few codes. I scanned with VCDS so hopefully some of you wizards can help me decode whats going on. If i missed any crucial info let me know and I'll throw it in the thread.
Thanks a ton
-Dave
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 4F 52 56
62 72
VIN: 3VWPL7AJ4DM620484 Mileage: 142430km-88501miles
01-Engine -- Status: Sporadic communication error 1000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 E HW: 03L 907 309 AA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H15--- Serial number:
Coding: 0350078
Shop #: WSC 74291 008 00000
VCID: 30391D2B2620D93ABFB-8064
VINID: 0E69E070745A114746080108102550E76D
No fault code found.
Readiness: 0 0 0 X X
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 062 B HW: 02E 927 770 AL
Component: GSG DSG AG6 512 9430
Revision: 05551213 Serial number: 00001206080346
Coding: 0000020
Shop #: WSC 00066 000 00000
VCID: 1471B1BBB278051ABB3-8040
5 Faults Found:
17252 - Transmission Fluid Pressure Adaptation at Limit
P0868 - 001 -
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 235
Reset counter: 2
Mileage: 139219 km
Time Indication: 0
Date: 2017.10.29
Time: 18:06:55
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 0
Reset counter: 39
Mileage: 142349 km
Time Indication: 0
Date: 2018.02.07
Time: 00:03:39
28907 - No Communications with Cruise Control (Front) Distance Sensor
U0235 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 38
Mileage: 142349 km
Time Indication: 0
Date: 2018.02.07
Time: 00:03:39
01196 - Engine-Transmission Data Bus
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 2
Reset counter: 38
Mileage: 142349 km
Time Indication: 0
Date: 2018.02.07
Time: 00:03:40
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 7
Reset counter: 1
Mileage: 142349 km
Time Indication: 0
Date: 2018.02.07
Time: 00:16:57
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 114B600C492400FA880F06EC921D0042B70000
Shop #: WSC 02134 444 103378
VCID: 7DA7F41FADF2E45264D-8028
6 Faults Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 178
Mileage: 141708 km
Time Indication: 0
Date: 2018.01.20
Time: 07:32:60
Freeze Frame:
Count: 0
Count: 32768
Count: 12800
Count: 16401
Count: 50944
Count: 1
Count: 2042
Count: 0
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 208
Mileage: 142349 km
Time Indication: 0
Date: 2018.02.07
Time: 00:03:39
Freeze Frame:
Count: 3
Count: 14
Count: 4096
Count: 8194
Count: 43776
Count: 0
Count: 1024
Count: 0
01325 - Control Module for Tire Pressure Monitoring (J502)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 168
Mileage: 142349 km
Time Indication: 0
Date: 2018.02.07
Time: 00:03:21
Freeze Frame:
Count: 3
Count: 14
Count: 20480
Count: 16390
Count: 43776
Count: 0
Count: 1024
Count: 0
00778 - Steering Angle Sensor (G85)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 168
Mileage: 142354 km
Time Indication: 0
Date: 2018.02.07
Time: 03:22:34
Freeze Frame:
Count: 3
Count: 0
Count: 4608
Count: 293
Count: 50688
Count: 1
Count: 1278
Count: 0
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 168
Mileage: 142349 km
Time Indication: 0
Date: 2018.02.07
Time: 00:00:58
Freeze Frame:
Count: 16391
Count: 12
Count: 16896
Count: 80
Count: 44800
Count: 0
Count: 1024
Count: 0
00285 - ABS Wheel Speed Sensor; Front Right (G45)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 168
Mileage: 142349 km
Time Indication: 0
Date: 2018.02.07
Time: 00:00:58
Freeze Frame:
Count: 16391
Count: 12
Count: 16896
Count: 48
Count: 44800
Count: 0
Count: 1024
Count: 0
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 085 0902
Revision: 00085000 Serial number: 0181163123 Dataset Number: 5K0116v____ 1K07
Coding: 030C0C
ASAM Dataset: EV_KESSYPQ35G A02013
ROD: EV_KESSYPQ35G_A02_VW31.rod
VCID: 3431113BDEB8E51ADB3-8060
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 BH HW: 7N0 907 426 BH
Component: AC Manuell H20 0505
Revision: 00001018
Coding: 0010002002
Shop #: WSC 00066 000 00119
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 7BA3FA07B366EA625A9-802E
1 Fault Found:
13701376 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Motorsteuergerät - kein Signal/Kommunikation]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Reset counter: 208
Mileage: 142349 km
Date: 2023.09.17
Time: 00:03:38
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 J HW: 5K0 937 084 J
Component: BCM PQ35 B 021 3068
Revision: BG021001
Coding: 6F380E1F802F3EC4008800C17000004449000086575D05F064802020A040
Shop #: WSC 64475 002 1048576
VCID: 392F200FF95A1872085-806C
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 15081 26 0512
Coding: 009795
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 208
Mileage: 142349 km
Time Indication: 0
Date: 2018.02.07
Time: 00:03:40
Freeze Frame:
Term 15 On
Voltage: 12.30 V
ON
ON
OFF
OFF
OFF
01565 - Luggage Compartment Light (W3)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 254
Mileage: 139219 km
Time Indication: 0
Date: 2017.10.29
Time: 16:25:12
Freeze Frame:
Term 15 On
Voltage: 12.25 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 M HW: 5C0 959 655 M
Component: AirbagVW10G 014 0726
Serial number: 003L4R00897- Dataset Number: 1KM003v__B_ 0047
Coding: 00004E42
ASAM Dataset: EV_AirbaVW10SMEVW360 001026
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3C21391BF6E82D5A133-8068
Seat occupied recognition:
Subsystem 1 - Part No SW: 1KM 959 339 B HW: 1KM 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--000058VZ00
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME2F701269ZZZZ
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME1F336567ZZZ/
Rear Side Airbag Crash Sensor (on driver's side):
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME5145102EZZZD
Passenger side rear thorax airbag crash sensor:
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME7949102EZZZS
Crash sensor for front airbag: driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME4A54012EZZZG
Crash sensor for front airbag: front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME0414042EZZZ6
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 521 BR HW: 5K0 953 569 E
Component: LENKS.MODUL 014 0140
Revision: FF010041 Serial number: 20120629101151
Coding: 100A140000
Shop #: WSC 00066 000 00184
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DA7F41FAD72E45264D-8028
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Coding: 820000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K0 920 973 C HW: 5K0 920 973 C
Component: KOMBI H05 0705
Serial number: 00000000000000
Coding: 270F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 313F182F21AAD032B05-8064
1 Fault Found:
12648448 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Motor: keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 208
Mileage: 142349 km
Date: 2023.09.17
Time: 00:03:37
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 T HW: 7N0 907 530 K
Component: J533 Gateway H40 1632
Revision: H40 Serial number: 16081203290319
Coding: 352002
VCID: 41DF48EF918A40B2405-8014
1 Fault Found:
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 208
Mileage: 142349 km
Time Indication: 0
Date: 2018.02.07
Time: 00:03:39
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0705
Serial number:
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DCF43CCFC63EAB1F-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 B HW: 5K0 905 861 B
Component: ELV-PQ35 H20 0240
Revision: 00000000 Serial number: 12000162935005
Coding: 4900000000000000
Shop #: WSC 00066 790 50316
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2F3B1E57379EC6C2A61-807A
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7663055893
Coding: 020100
VCID: 2A0D0F430CFCA3EA71F-807E
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 208
Mileage: 0 km
Time Indication: 0
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 D HW: 1K0 035 274 D
Component: RNS315-NAR H53 0319
Serial number: VWZAZ2M4262039
Coding: 04000401040007000000100A
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_RNS315NARV2UDS 001705
ROD: EV_RNS315NARV2UDS.rod
VCID: 2517FC7F65628C925CD-8070
Data carrier:
Subsystem 1 - Part No: 3AA 919 866 B
Component: NAR_V3_(0037) 0037
1 Fault Found:
1048669 - Tuner for Satellite Radio
B11CF 53 [009] - Deactivated
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 254
Mileage: 139219 km
Date: 2023.06.08
Time: 16:24:56
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0005249181
Coding: 0004B5
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW36.rod
VCID: 5BE39A8713A60A623A9-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 008 1509
Serial number: 00000007002440
Coding: 000490
1 Fault Found:
68108 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Front CAN MSG]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 208
Mileage: 142349 km
Date: 2023.09.17
Time: 00:03:38
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 372B2637C34E0E02FE1-8062
2 Faults Found:
01316 - ABS Control Module
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 168
Mileage: 142349 km
Time Indication: 0
Date: 2018.02.07
Time: 00:01:24
Freeze Frame:
Voltage: 12.25 V
DD
Temperature: 26.0°C
RPM: 0 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 208
Mileage: 142349 km
Time Indication: 0
Date: 2018.02.07
Time: 00:03:39
Freeze Frame:
Voltage: 12.25 V
DU
Temperature: 28.0°C
RPM: 1498 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 K
Component: EZE_2 H40 1632
Coding: 050B0500
VCID: 6FBBDE57F79E86C2E61-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H03 0220
Serial number: 0123456789ABCDEFGHIJ
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H03 0220
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0005284519
Coding: 0004B4
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW36.rod
VCID: 5CE1999B16A80D5A333-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 008 1509
Serial number: 00000007021958
Coding: 000490
1 Fault Found:
U1111 00 [008] - -
[Front CAN MSG]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 208
Mileage: 142349 km
Date: 2023.09.17
Time: 00:03:38
End----------(Elapsed Time: 01:27, VBatt start/end: 14.3V/14.3V)-----------
