Jason25klein
2001 jetta tdi 1.9. Won't make any power. Only goes to 2000rpm and when I unplug the maf sensor it'll Rev to more. Replaced it and still the same.
And have you taken a look at the intake?I unhooked the exhaust. All new filters it doesn't smoke at all. Idles a d starts like new
I had an ALH with no CEL but the intake clogged with carbonWow, some parts. ECUs rarely fail like that. Try careful troubleshooting using the Scientific Method. Could be a clogged intake. Partial removal of the EGR stuff will get you a look see. It will be nasty, needs to have an opening somewhat larger than a dime. If you don't have the VCDS device, you may want to pick one up. Or find a TDI experienced mechanic.
