TDI Jim
- Joined
- Jul 10, 2006
- Location
- Gaithersburg, Maryland
- TDI
- 1996 Passat, 1996 Passat Variant (RIP), 2002 Jetta Wagon, 1995 Passat Variant TDI conversion brought back from the dead, 1997 Passat Variant project, and returned 2014 Passat
I need pictures of the routing of the coolant hoses and electrical connections for my 2002 Jetta Wagon rebuild project as I put it back together. The car started life as an automatic, converted to 5 speed by the previous owner, and now I am installing a newer engine and 6 speed O2M Manual transmission and dieselgeek short shifter, deleting the EGR and upgrading turbo and nozzles. I am getting ready to put the radiator, condensor, and front on so need help figuring this out, specifically:
1. Top radiator hose connector between the 2 hoses as there may be a coolant temperature sensor I was not aware of, since the hose barb does not have a place for the hose to go to from what I see. Also the oil cooler hose routing.
2. The electrical connections off the black conduit loom that is behind the battery.
3. How the wiring looms are secured in the engine bay
4. For an 02M transmission how the power steering hardline is secured by the transmission bracket, so it does not hit the side to side shifter mechanism nor wear on the bracket as it is a very small space.
Thanks everyone, I have to get this car back together and running this weekend due to an unexpected move!
