pmoulton5018
So I have a mk7 golf with a Malone stage 2 tune, turbo back exhaust with deletes and an injen cai. I was wondering what would be smart for me to do next. Eventually I want to upgrade to a gtb2260.
theres no point in wasting the money on cr190 turbo if the end goal is gtb2260. Spend the money once spend the money right.Or a CR190 turbo.
Fitting a FMIC in addition to the air/water intercooler?? I don't believe that's necessary.As of now I have a 3" turbo back. Exhaust. I'm gonna get a nuespeed FMIC. A cp3 and I gonna jump to a malone stage 4 tune. I'm looking to get a tubular manifold from dark side. Also getting a stage 3 water meth kit
Water/meth kit isn't an air/water intercooler.Fitting a FMIC in addition to the air/water intercooler?? I don't believe that's necessary.
Sent from my Nexus 6P using Tapatalk
The EA288 has a water/air intercooler like the CKRA Passats. Running an FMIC means adding a bunch of piping to the current setup, or ditching the air/water and fabricating an entirely new intake manifold which is a ton of work for what gain? We need to see pre/post intercooler intake temps before thinking a supplemental intercooler or entire replacement is worth the trouble. I was under the impression our water/air units were pretty darn good, and I'd be happy to run some logs to see exact figures.Water/meth kit isn't an air/water intercooler.
Our water/air intercooler on the EA288 is integrated into the intake manifold. It gets air also blown onto it through the top most opening in the front grill where the air intake also gets its fresh air. We do not have a SMIC or FMIC, which equals a very short charge air tube. There is also a warm air snorkel that goes from the bottom of the stock airbox to right above the turbo to aid in warm-up which disconnecting could help reduce temps as well. I may do some logs of temps with and without that warm air snorkel and see what happens.Hmmmm did not know this. That would be interesting to see the figures. I just figured an FMIC is better than stock. It's side mount right? And if so would you think it'll be benifical to get an upgraded side mount?
Very interesting, thanks for the schooling.The EA288 has a water/air intercooler like the CKRA Passats. Running an FMIC means adding a bunch of piping to the current setup, or ditching the air/water and fabricating an entirely new intake manifold which is a ton of work for what gain? We need to see pre/post intercooler intake temps before thinking a supplemental intercooler or entire replacement is worth the trouble. I was under the impression our water/air units were pretty darn good, and I'd be happy to run some logs to see exact figures.
