BRUSSELS BELGIAN
Old Whig
Since I'm mechanically illiterate, I welcome comments on a CUTE car I'm looking at: 1988 MB 190D with the naturally asperated 2.5 diesel. Any horrible issues with these cars, other than typical German torture issues?
Today, it is 102 degrees in Baltimore and Philadelphia! When I drive the 05 Passat home...how did you know, that to save precious fuel...I will NOT be using my air conditioner!Well it's a benz so it will be expensive. The rear suspension is probably dead, and there are a lot of rubber bits back there. That 2.5 will be a reliable, if abit slow, powerplant. If the air doesn't work it could be spendy to fix properly. (I forget, do you ever use the AC Jack? Would that dip into your MPG pot too much? ) Check that the sunroof works, it probably needs $200 worth of parts replaced as well.
Is it a stick or an auto?
-J
