Toronto_Vento
So, here's the deal. My '01 Jetta is up for plate sticker renewal, and needs to do the emissions test. Totally forgot that it's no longer a visual check. Go to the shop, and machine can't communicate....cigarette lighter fuse. Okay. Run the scan and fails...turns out my Rocketchip tune (from forever ago) does something which doesn't allow the scan to complete.
My solution was to pick up a used ECM and stick it in for the emissions test. Got it installed, got it to sync up with Vag Com and started the car up. No problems. Idles fine. I went to take the car for the emissions, and while it has no issues at idle or when accelerating, when coasting it shakes fairly violently and is displaying the check transmission indicator. I apparently picked up a 5 speed module (my car is manual tranny), but I'll have to verrify that the ecm I got isn't in fact coded to auto. Would this throw the symptoms mentioned above? Other thing is that my EGR is essentially dissabled (stealth pipe).
Is there anything else I should be looking at which may cause this behaviour? I got a little down the street and turned right around as my car would never pass with this issue. I can swap ECMs to get my Rocketchip back, but that obviously wouldn't help with my emissions check.
Been a while since I've had to use Vag-Com, so I'm trying to find the proper spots to check whether the ecm is set to manual or auto, and how to do the EGR turndown. I'm hoping I can get another year or so out of this car, but who knows...maybe the car is trying to tell me something. LOL
