Hello everyone.
I have attempted a conversion from Dual Mass Flywheel setup to single mass.
The car in question is Golf Mk6 2011 year with 1.6 TDI engine, code CAYC.
I installed a second-hand flywheel, VW part number 037 105 273 C.
I also installed clutch and pressure plate from G60, Sachs part number 3000 332 001.
While I was there, I also replaced master and slave clutch cylinders as I do a lot of city driving.
However, upon reassembling everything back, I faced a problem - I was unable to start the car.
Cluster kept showing message "Depress Clutch".
I realised that the clutch pedal doesn't reach very bottom. There is about 2 cm distance left from the lower stop.
If I press really hardly on the clutch pedal, the car starts.
It shifts and drive fine....
What I did wrong? Is my single mass setup wrong? Could anyone please give some ideas as at this point I'm deseperate...
