need help asap starting problem
trim351
maple city
on the hunt
i have a 02 jetta when you go to start it. it acts like its got a bad ground and doesnt turn over but if you cycle the key and keep trying eventually it will start some time taking longer than others please help getting tired of not knowing when it will start and when it wont
BolaB4V
Northern NY
1996 passat tdi wagon, 97 F-150 XLT 4x4, 99.5 Mk4 Jetta VR6/5M
Have you (re) searched? looked under the hood? Got fuel? Ignition? etc.
Ski in NC
Wilmington, NC USA
2001 Jetta ALH 5sp stock
Need two people: One with a voltmeter and one to turn the key. Turn key to start and hold it there (only hold it there if starter does not spin). Then take volt meter and measure voltage on battery posts, cable lugs, starter terminals. Find where voltage is and where it is not.
Journeyman
sw michigan
96 passat tdi, 01 jetta tdi
If you have no voltmeter start with cleaning battery posts and terminals with wire brush. If still weak see it jumping it makes a difference. If still weak then you will need the meter and follow instruction above.
Woookie
Eagan
1997 Jetta TDI
oy check the signal wire ive seen like 5 in the past month where the wire has broken off....just a thought and a 02 jetta is a Mk4 not a Mk3 not to be an ass
