300D
So, I am starting a new thread, instead of continuing in the metal chunks thread: http://forums.tdiclub.com/showthread.php?t=503708 as the questions aren't about the metal chunks anymore.
Background: I have dived in to swapping my cylinder head.
Current setup is driving a bit warm, using coolant, suspected a blown head gasket. Tested positive for exhaust gasses in the coolant. Also a bunged #4 glow plug. Long story on that one, but head not repairable.
Picked up a spare engine last spring with only 110,000 miles.
Plan was to swap the spare engine’s head into the car with no head refresh. Pulled spare engine’s head and it looks great. Spare engine also looks great.
Started pulling head from the engine in the car. Drained oil and found pretty good sized metal chunks on the magnetic drain plug. Then pulled oil pan to make sure everything on the underside looked good. All good except for an additional piece of metal in the pickup screen that looks like a piston wrist pin. A 3/4” diameter round spring wire.
Then went up top and pulled off the head. Found some interesting things that I need feedback on:
First, when pulling off the head. Two head bolts between cylinders three and four were loose. Which might explain a bunch of my on going issues. No idea why I didn't check this.
Three and Four cylinders were very oily and a tiny bit of coolant evident. Here is a picture immediately upon removal:
Spent a little bit of time getting started on cleaning the block:
All the cylinders looked fine except for cylinder number 4:
How bad are these marks/scoring? Why are there marks horizontally? I can feel the horizontal marks, but not the vertical ones.
Should I continue with my plan? Just put the head on and go for it. No compression test was done as there is no glow plug hole in cylinder #4. Or should I rethink? Is there a way to hone in place? How involved is it to pull the pistons and put new rings on? Pan is not sealed back on yet, so that part is easy. I do have a spare engine, but really wasn’t planning an engine swap in late November in Maine in my driveway.
Thanks for feedback.
